dunbarhamlin
At least be realistic with your numbers - 1 thousandth of an inch is commonplace with half a thou closer to the normal limit
custard":3bw8947j said:woodbrains":3bw8947j said:if we take 1 thou shavings with a very sharp plane, and overlap the strokes, the difference beween the high and low points will be 1 thou or less. This is less than the film thickness of most reactive finishes.
Mike.
Two points,
1. The "ridge" (ie the peak between overlapping planing furrow that's at risk of having the finish removed with subsequent sanding) is governed more by the camber of the plane iron than the thickness of the shaving.
2. Where did you get the information on finish film thickness?
Take a wood finish such as pre-catalysed lacquer as guidance for other film finishes. Manufacturers of these lacquers all recommend a wet film thickness of approximately 100 μm (microns); 100 μm is about the same thickness as a typical head hair. If you work in mils (1/1000'ths of an inch) all the polish manufacturers recommend a wet film of 4-5 mils. The other part of the equation is number of coats to apply, and with pre-cat this must be limited to three maximum at those wet film thicknesses. (This maximum wet film thickness is to prevent cracking or Chinese writing developing in the fully cured finish.)woodbrains":36el9uh2 said:Film thickness, I cannot find a ref for it amongst my books, but I know I have come across it several times I'm sure you could find it on the web. A rule of thumb is, you only rub out a finish when the thickness is about 6 thou. Three coats of poly will be this thick or a touch more. Therefore minimum 2 thou per coat. Mike.custard":36el9uh2 said:2. Where did you get the information on finish film thickness?
