After each hit you waggle it slightly and it comes lose (thanks to the taper etc) but if not you just hold down or tap the workpiece with the mallet conveniently located in your other hand. Clamping just slows things down and the clamp may mark the sides.Pete Maddex":1dittkux said:Jacob, how do you get the chisel out if you don't clamp the wood? or do you just have lumps of wood with lots chisels stuck in them?
Jacob":1uzpqmwe said:After each hit you waggle it slightly and it comes lose (thanks to the taper etc) but if not you just hold down or tap the workpiece with the mallet conveniently located in your other hand. Clamping just slows things down and the clamp may mark the sides.Pete Maddex":1uzpqmwe said:Jacob, how do you get the chisel out if you don't clamp the wood? or do you just have lumps of wood with lots chisels stuck in them?
The mortice stool / saw horse idea - you hold it down with your bum - quick release and no risk of marks and a very efficient ergonomic working position.
It's a bit like rip-sawing - fast and furious - there would be a lot of them to do so slowly and carefully wouldn't do at all.
You can't hold in a bench vice as it will mark the sides as you whack the chisel. It has to sit on a bench i.e. supported underneath. Across bench hooks is good as the chippings fall free and don't get under the workpiece.Pete Maddex":1xh8a6zw said:Jacob":1xh8a6zw said:After each hit you waggle it slightly and it comes lose (thanks to the taper etc) but if not you just hold down or tap the workpiece with the mallet conveniently located in your other hand. Clamping just slows things down and the clamp may mark the sides.Pete Maddex":1xh8a6zw said:Jacob, how do you get the chisel out if you don't clamp the wood? or do you just have lumps of wood with lots chisels stuck in them?
How the hell does clamping slow things down? the wood is fixed so no need to hold it down with the mallet in your other hand, possibly marking it and getting bits underneath it it lifts off the workbench, which will mark the underside, don't tell me this has never happened to you.
A clamp and a pad will make things much easer and quicker.
Either we are conversing at cross-purposes, or we work differently. The only time I "steer" a mortice chisel is when placing it in position at the surface. The chisel is aligned square to the mortice lines, and then struck straight down. I do not seek to steer it on its journey straight down, nor does it need to be steered.
The only chopping direction is straight down. I learned that this is the method advocated by Maynard. No attempt is made to lever out waste. The waste is being forced into the (drilled) hole on the right (obscured in the photo).
Jacob":28awtinf said:The mortice stool / saw horse idea - you hold it down with your bum - quick release and no risk of marks and a very efficient ergonomic working position.
AndyT":3oth4395 said:Gentlemen, I expect you are both right, but are thinking of different examples.
Imagine a small cabinet door stile, probably only 12 - 15 mm thick, 30 - 40 mm wide, 300 mm long. You'd need to clamp it down to stop it falling over.
Then imagine cutting mortices in a five bar gate - it's a different scale entirely. It would make sense to use a low bench/stool and hold the wood down by sitting on it.
Woodwork covers so many different specialist trades. Carpentry is not the same as joinery or cabinet making, but anyone used to one trade will sometimes need to have a go at another. I think this is often the cause of differences of opinion in online discussion.
Yes if it's narrow enough to be unstable.AndyT":2daehe56 said:Gentlemen, I expect you are both right, but are thinking of different examples.
Makes no difference which way round. I used to start in the middle but with the face facing the far end and then advance it face forwards for each cut, up close to the end then turn it and bring it face forwards to near the near end.bugbear":bhtlwqvu said:...
I think you're misremembering Derek; Maynard's technique has the bevel the other way round.....
It's not the size it's the stability. If you cut a 1/4" mortice in a 1" square workpiece you don't need to clamp it - but you might if it was 1"x4"bugbear":3dlhbw2k said:AndyT":3dlhbw2k said:Gentlemen, I expect you are both right, but are thinking of different examples.
Agreed.
When the workpiece is big enough it's held in place by inertia and gravity. Timber framers don't use many clamps!
BugBear
bugbear":3lbclicy said:Either we are conversing at cross-purposes, or we work differently. The only time I "steer" a mortice chisel is when placing it in position at the surface. The chisel is aligned square to the mortice lines, and then struck straight down. I do not seek to steer it on its journey straight down, nor does it need to be steered.
Here's Jeff Gorman with the original article, and some experiements;
http://www.amgron.clara.net/maynard40.html
Jeff's pages on the topic followed a discussion I started on OLDTOOLS in 2001 (!!)
http://swingleydev.com/ot/get/99408/thread/#99408
BugBear
Thats how I do it. Don't need a starter hole though. Each slice goes deeper than the one before so its a lot faster than you expect...
Jacob, you asked what the purpose of the drilled hole was. It is to create a space for waste to move into.
Here is a relevant photo from Jeff's web page ..
The chisel back is vertical, and the bevel forces the waste towards the hole. The next chop of the chisel forces the waste into the gap of the previous chop. And so on.
Regards from Perth
Derek
Try it without a starter hole and you will see where the waste goes.Correct Pete ... well close to full length.
Jacob, waste has to go somewhere ...
Regards from Perth
Derek
But you've got to drill a hole. By hand (brace and bit) it'd be much quicker just to chisel. Probably same by machine by the time you've set it up etc. Might as well get a morticer.Pete Maddex":2jky55jg said:With a starter hole you can go to full depth from the first chop, much faster than you expect.
