At a minimum of 135mm I would lose 60mm of cupboard space as my existing plinth is only 75mm high.
Wind the foot into the leg, then cut off the amount you don't need. I did this on mine as i only want 65mm high plinths. Easy with a hacksaw :wink:
How they fit depends on what they are. Most washers, dryers and dish washers just slot into a 450mm, 500mm or 600mm gap between cabs and have the door hung on special hinges or fittings. This means you'll need a 35mm hinge boring bit either for the router (Wealden Tools) or in a drill press - don't try using one by hand. The normal approach is to pack-up and jack-up the appliance up so that its top rests against the underside of the worktop - I normally use the cut-outs/offcuts from the worktop to do this. Many such appliances can be screwed into the cabs on either side or into the (underside of) worktop to stop them "walking" in the event of vibration. Check the heights of these appliances as they'll generally specify something like minimum height underworktop of 830 to 850mm. If installing anything which can generate steam when the door is opened (e.g. washing machine or dishwasher with drop-down door) the underside edge of the worktop should be protected by applying a strip of self-adhesive ally foil, like gas fitters use (try Screwfix). This will prevent the steam from delaminating the worktop at the edge of the post-forming. Most insert appliances require 550 to 570mm depth of carcass, so your services (electric, water, waste outfall) should be positioned behind an adjacent cabinet - there's no space for them directly behind the appliance itself. Plinths are normally just run across the front and clipped to the legs of cabs on either side. Drop door appliances will need a cut-out to be put in the top of the plinth, but the details will be in the instructions.ByronBlack":ay35y30z said:I have a couple of other questions regarding appliances. How do they fit into cabinets? I'm assuming the cab has no base and just slips over the appliance on the top and two sides? Also, are appliances usually the right depth to fit into a cab/under a worktop and how are the kickplates/plinths catered for?
The job requires two spirit levels, a 1m builders level and a smaller torpedo level and is actually quite quick once you get the knack.engineer one":ay35y30z said:...it is just the whole concept of flattening one cabinet against another.
In the USA they have overflow drainer trays just like that, I think because they have a lot of wooden houses, and I wish we had them here. But we don't so I'll stick with what we have and work accordingly.engineer one":ay35y30z said:...personally I think it would be better to design a kitchen so that water overflows are captured in a more sensible and safe way, you know washing machine water capture things etc,
I agree with others that you are probably getting near the limit. The issue isn't so much the drop required to handle the solids, it's the height of the stand pipe above the P-trap in the waste outfall you'll need to ensure that the dishwasher and washing machine don't back up overflow the pipe and so flood the kitchen. Some machines can pump out at a heck of a rate and will need a good 450 to 500mm of stand pipe height - that doesn't leave you with a lot of drop to play with when you take the P-trap and curvature of the flexi waste pipe from the appliance into account. That's one of the reasons it is normal to install waste water water producers near to the sink. The other is pure ergonomics. Consider the working triangle of sink - fridge - cooker which needs to be no more than 10ft (3m) on each side for a good working kitchen; I reckon the same is true if dish washing and/or laundry facilities are incorporated. You really need the dishwasher right next to the sink so that you can rinse off the muckiest stuff before loading it into the machine. Similarly for laundry you don't want the washer too far away from the sink so that heavy, waterlogged, pre-soaked or scrubbed items don't have to be dragged all around the kitchen, dripping all the while before you load them into the washing machine. If you keep the washers near to the sink then it should be possible to plumb-in the wastes through something like a 1-1/2 or two bowl kit with single or even dual waste spigots (although in all probability your sink will come with provision for at least one such connection):ByronBlack":1cacpxwq said:The only other thing that is causing me a few problems (mentally) at the moment is the waste to the washing machine and dishwasher. Currently these are situated near the sink but I want to move them about 10ft across the kitchen to the back wall - how difficult is it to move the waste pipe (I might have to run it outside the house and back in) and what is the minimum angle needed to carry the waste out?
You don't say? :wink:ByronBlack":1cacpxwq said:Sorry for all the questions, it's the first time i've looked into a kitchen project.
Do yourself a favour, Byron. If you can get a Duropal (Pfleiderer) or Prima (Formica) 38/40mm worktop at a reasonable price then go that way. The better quality worktops are generally a lot easier to joint well as they tend to have less of an across the width dip in them. When they are delivered put them in the garage or get them in the house right away as leaving them outside in warm weather like today or on days when the RH of the air is high will simply create a lot of problems for you when you do install.ByronBlack":1cacpxwq said:....I'm going to go for a cheapish laminate wood effect worktop.....
Well, I'll admit to having a slightly different one. The one I showed was about as cheap as they get. I have this orange one (£11.60 + the dreaded):engineer one":3h8cqibd said:....how about that you have shown the picture of a tool I got given ages ago, and still have never figured out how to use it.
What do the bits inside the handle do?? and how do you open and use it?
