Yes, that's the set up she wants. I reckon with the 900mm ones, you can put what you like above them and nobody will ever see it
You mean she does not dust up there
95% of doors are 720 high so you need 140-150 plinths to give the usual 900-910 working surface.
If you start making the doors much taller it can give problems with bottom hinged built-in appliances like dishwashers unless you go for Fisher & paykel draw ones with integrated fronts. If you are worried about loosing space then fit plinth draws.
Jason
