Flattening a plane sole.
phil.p":38e4f95g said:
Bin the thing and spend a £5 at a car boot for an older Stanley or Record? They might not be perfect but they'll be better. And worth correcting.
+1 I use a 1930's #5 for work. Gorgeous to use.
Bedrock":dr5ro3wz said:
I agree with JohnPW, file or scrape the centre 'til you are flat or even slightly convex, then back to the abrasive on a flat surface. I cannot think of any way you can remove a convex cross section by hand. I have a Norris 5 with exactly this problem which is overdue for treatment, so if anyone has a better method than the above, please enlighten me.
Mike
...scrape the centre 'til you are flat or even slightly convex...
Did you mean concave?
BugBear
wizard":36by45do said:
depending where you are in Cornwall just fished this out of my scrap bin may have the screws as well if you want it its free to a good home. and its very flat.
That is very kind but I'd really like to get this plane working, thanks a lot for the offer though!
I think I'm going to pop down to trago and get a flat file and try to file the centre down. I managed to get hold of a small piece of float glass so I'm going to put some sharpie on it to use as a spotting surface. I think I may have an old file somewhere I could convert into a scraper so once the bulk has been taken out with the file I'll have a go at scraping the sole.
Cheers for the replies everyone!
Bite his hand off! - Seriously take advantage of that offer for 2 reasons - it's flat, so it might be a simple transplant of bits, and if not I'm sure there's enough others here to cobble one plane usable together and that sole is a corrugated version, not so common now and some say they genuinely make a difference to the ease of using (the corrugations were designed to reduce friction between the wood and plane therefore making it less strenuous to use) - having suffered from "planers armpit" (and planers bell - don't ask) when I started to do a lot of planing I can say anything to make it a bit easier is a good thing.
I strongly advise you take Wizards plane sole offer - it's a better offer than you might think, see my other post.
You can still get that faithfull plane to work though - Once I got my old Stanley #4 I altered my faithfull to be a scrub plane, so it still gets used and the best bit is for a scrub, the sole doesn't even NEED TO BE FLAT!!
Here's a convincer link:
https://www.youtube.com/watch?v=XN5QSTaVzRQ
phil.p":3wxes0sv said:
You might be making hard work if you get a file from Trago - it's likely to be softer than the sole of the plane.
And unless your filing skills are good, you'll make more trouble for yourself. Filing flat
is quite the Art.
BugBear
Don't get me wrong, I would definitely like to have that plane sole, it would just be quite a hassle for me to make my way up to Redruth as I don't drive.
Maybe you're right about the filing, perhaps I could use selective sanding for the rough work - a corner of a sanding block and some 80 grit sandpaper - using the float glass as a touch plate. I can always use a finer grit if I'm worried about taking too much metal off at once.
Frivolity aside - you are a novice. Unless the thing has a sole the shape of hull of The Scillonian, spend your time learning to sharpen the iron properly. You will learn more and your time will be much better spent.
A novice at woodworking I am, but sharpening I am not - I already have a shaving sharp plane iron having spent quite a lot of time sharpening kitchen and bushcraft knives over the years. I get your point about time usage though.
Well I know a bargain when I see one. If there's no other takers, Wizard would you be prepared to send the sole up to me if I cover postage ?
yes
I was refraining from doing this as I was trying to encourage the OP to take advantage and save himself some effort and see how much a well fettled plane will improve the learning experience - especially on the back of the other recent thread about the quality of modern planes; I doubt the cost of even posting it to him would be much, less than the cost to Trago and the file... but I guess I should have just done what nOlegs did, regardless of Wizards generosity and intention.... "jumping in someone else's grave" springs to mind.
Flattening - how I'd do it (a variation on 'scary sharp'):
The idea is to use a narrow strip of abrasive sheet, and chock up the sole so that said sheet only abrades the sticking out bump in the plane and doesn't do the whole sole. The "chocks" are electrical tape, encouraged to slide on the glass by lubricant. They stop the plane see-sawing.
Start by establishing exactly what the shape is - where is the convexity and how bad is it?. Once you know, stick down a strip of coarse wet+dry to a large piece of plate glass (my plate glass is about eighteen inches square). The strip only needs to be about half the width of the plane. Fix it down with glue from a new can of SprayMount (stand the can in really hot but not boiling water before spraying to get a finer spray, and spray the back of the wet+dry, NOT the glass!). Smooth it down immediately and solidly with a wallpaper seam roller. Give it time to dry off a bit before use.
On the plane itself, apply small squares of electrical insulating tape to the corners of the sole. Cut them with scissors or a knife so you don't wrinkle the tape. Build up two or three layers, or more, as necessary, on the corners, so that they support the sole high enough to cut in the middle area but not at the edges, and that it doesn't rock on the glass plate - may not be the same quantity in each corner, if the plane is convex because it's distorted, all bets are off as to how much you'll need.
Sight under the plane against a strong light to see that the bump is just lifted off the glass. Check it doesn't wobble, pack whichever corner needs it with tape. When it's solid, add two more thicknesses to each corner to lift it clear by roughly the thickness of the wet+dry.
Pick something suitable to lubricate the tape sliding over the glass - talc would probably do, or Liberon wax, but I'd proably stick with soapy water.
Blue the sole (big, permanent felt-tip pen), before starting, then remove individual pieces of tape in sets (one from each corner) until it starts to cut the high point. Work it gently until you have a flattened area and the wet+dry stops cutting. If that's too small (i.e. it's really uneven), take off one patch from each corner and repeat.
Use water with (literally) only one drop of washing up liquid per jug-full as cutting lubricant. Photographic wetting agent is even better if you can find any nowadays.
Find a strong magnet before you start, and put it in two clean polythene bags. As the grinding crud builds up, frequently remove it by passing the magnet low over the abrasive. When the outer bag has a pronounced 'beard', remove it from the magnet by turning it inside out, wash it off and you're good to go again.
This should give you a fairly large, dead flat area on the sole where the bump stuck out. when you think it's big enough so that you can balance the plane on it without rocking it (for the next step), stop. If it stops cutting but the area is too small, take off another patch of tape all round to lower the plane by that thickness and expand the area.
At that point you can remove all the sticky tape, and the wet+dry, clean the glass with meths, stick a fresh full sheet down and gently have at it again to get the whole surface down flat.
I know what people say about having everything in place on the plane to avoid it distorting, but if you look at the geometry of a Bailey plane, the frog causes little bowing effect unless something else is wrong with the machining to start with (a bigger problem). I've done mine with everything stripped off the main castings. That also lets you use one the threaded holes to fix on an improvised winding stick of some sort (if you want to), which should warn you if you're rocking the plane without realising it. If you're really concerned, I'd do the main flattening with a bare casting, as it's much easier, then reassemble it and finish it off once it's flat enough not to wobble, but honestly it's not a shoulder plane so the geometry and forces being applied are quite different.
It will take an evening or so to do the first bit, probably (on the kitchen table, in the warm, with a radio play on in the background), because you have to be careful. You also need a lot of newspaper because it's messy, and the damp filings will rust like crazy if left around.
When the sole is flat, finish off by wiping quickly dry then squirting it liberally with WD40, so it won't flash-rust (WD40 drives off water). I'd also store the bare sole on a radiator in this weather, so it's immediately in very arid air.
I haven't done this with a totally convex sole, but i have flattened several planes very nicely with a glass plate and wet+dry. They are sufficiently flat for stiction to be a nuisance when plaining some hardwoods (sometimes!).
I have also solved a similar problem with a handheld power plane: The two sections of the sole weren't in parallel planes - the front adjustable part had been cast badly, then machined out of true - tilted in two axes. In that case I kept the reference sole of the plane clear of the strip of wet+dry by strips of insulating tape. It worked very well, and salvaged an otherwise totally useless tool.
It occurs to me that you might help the alignment as you work the plane to and fro by fixing a batten to the glass to run the edge along. Do this with d/s tape, before everything gets wet, and weight it down for a short while so it doesn't immediately come loose once the water gets near it.
But then I don't do this stuff every day - only when I need to!
E.
PS: Forgot to say - float the plane over the abrasive, don't push down (put weight) on it. If you do push down, you roll the particles of abrasive over /bed them into the paper more, and they just blunt off faster and don't cut as well. it also clogs faster and more permanently. Push down just enough to feel the resistance across the paper, no more.
rafezetter":1najf8lb said:
I was refraining from doing this as I was trying to encourage the OP to take advantage...
To be fair, Wizard has been repeatedly turned down on his offer. And...
...does give the OP another chance to come to his senses, even gives him a push.
All fair and above board as I see it.
Cheers, Vann.
How is it going with the plane? I completely respect the desire to do as much as possible yourself but have you considered getting it machined. I had some twisted modern stanleys (4s and 5s) from a school which came free (along with a load of other goodies) when I bought a planer thicknesser. My local saw doctors (North London Saws) flattened the soles and machined the right hand sides square to the sole (for shooting board use) they charged me £25 for the first one and a £5 for additional ones. I kept a 4 and two 5s and gave the others away I certainly considered it money well spent.
You probably have somewhere local that grinds cylinder heads (ask any local mechanic where they take theirs).
Paddy
I'm sorry if you find it offensive, but I do think your comment is quite harsh.
My post is there in full view of all who wish to read it and says quite clearly "if there's no other takers".
I also say "I know a bargain when I see one". Everyone has had the same chance as I did to capitalise from Wizards very very kind offer that had been rejected.
Cheers, Vann.
Thank you Vann.
yes
Thank you very much.
Wizard I'll PM you.
