Sgian Dubh
Moving on to a separate issue, those Faithfull planes always seem to be hit and miss when it comes to quality and usability, and in my experience, they're almost always pretty ropey without a great deal of fiddling and correcting of manufacturing faults. Some I've come across have been so ropey they really weren't worth effort trying to get them to work.
In this instance, I noticed some photographs showed quite a large build up of ragged wood shavings trapped at the cutting edge of the iron or blade. This might indicate the meeting point between the cap iron or chip breaker and the blade is either gappy or the the leading edge of the cap iron has been ground in such a way that its front edge sits up from the blade. Both these faults lead to shavings getting trapped as in the photographs. However, that's only one potential issue, and being Faithfull planes I suspect there are a few more faults needing correction.
I suspect lee1596 might be best to find someone who knows their way around planes if he can to help him learn given his earlier admission that he knows very little about them. Slainte.
