And there you go jumping to arrogant religious fanatic assumptions. I’ve never posted anything about shaving shapes, curly or flat. I’m not going to post photos of the angles and positions of the cap irons on my planes because I have a life, but if I did you would see them honed and set as you describe. Not because it’s what you or any other fanatic is pushing, it’s because it was taught to me 50 years ago when I started using planes by my grandfather who was a lifelong carpenter and joiner, who probably learned it from his father who was also a lifelong carpenter and joiner. Using a cap iron has been about for generations why else is it there? FWIW all my woodworking (except construction work) has been completely dimensioned by hand. I don’t own a table saw or planer or thicknesses. I’ve spent a lot of time with handplanes and rough sawn timber.Perhaps I'm wrong, but you seem to suggest otherwise by seemingly disregarding any talk of straight shavings! (call'em what you like) ...
i.e, ones which are evident that the cap iron was involved, and not charmed by Shapton's outta
the plane.
As said Rob's somewhat disregardful of the use of the cap iron, not honing his to become more involved...when the going gets tough.
Setting it roughly a bit over 1/32" which might? just about work with thick shavings (on pleasant timbers) if honed at 50.
He doesn't hide that, but has a glut of videos to make things difficult to find,
so you won't see too many times it fails, or the fact he's constantly relying on the edge.
A different story, say if you're working even for 10 mins with a plane, on something not so pleasant
to work without using it.
Tom
My comment was railing about the exact response you have just made. Frankly I couldn’t give a toss what sort of shavings you make and I wouldn’t dream of telling you mine are right and yours are wrong.
I suggest you read your responses to this thread and reflect on the point I was actually making about self appointed gurus and how it applies to yourself.
