I've found I can make the joint without needing fishtail chisels although they'd be nice they aren't a 'must' the key is pairing down out from the centre on the pins as long as it's bevel edged, you could easily pick up an old pair of BE chisels off fleabay and grind them out of square. I've often wondered if they'd even save time or not to be honest...
I'm intrigued.... please do tell what you use them for.I have both - never get the fishtail chisels out and the only set of skew chisels that I have is something that most of you guys wouldn't guess the use of (they're about 1 1/2 inches wide - and not for a lathe).
I've never seen a center pin like that on an older piece of furniture.
Agree here. It's all I ever used (Marples by choice. ) From Workshop Heaven I bought a set of dovetail chisel and included were two fish tails. The chisels. as a set seemed too light for me and I sold them on. I have also seen a couple of bevel edge chisels that were ground into a 'whale-tail' shape but I can't recall who made the video. Might have been Rob Cosman.1/4" bevel edge does it. File it down if it's a bit chunky - some of them are a bit crude.
David, you are looking at the wrong furniture!
Regards from Perth
Derek
The tails seem to have about 1/8th at the thin end and I like the proportion of that with the pins on the end better than the ultra thin ones.
Hi TomNice work Pete, like the look of that.
Could I trouble you for some dimensions?
How wide is it at the bevel end
How wide is the narrower shank
How much splay does the fishtail have
thanks Pete, I’ve got some 3mm O1 already I was going to use (left over from making a new blade for a plane) so may give it a go this week.
Without a lathe the handle will be a more basic affair though.
That’s the semi plan, though may go octo as can just knock the 45s off a square block.Hexagonal tapered one like the old carving tools, I made one from ash years ago and its had a good pounding and has held up very well, even with out a ferrule.
