Sorry yes - the great and notorious heavy-weight Oval Bolster Mortice chisel!OBM??
If the line (pencil?) is thick enough to be split, surely it cannot be accurate?Why would you split the line surely your going to get sloppy joints?
I'd always cut to the waste side of the line in any tenon?
Or I've missed something?
Mortice and tenons you'd do with a two pin mortice gauge.If the line (pencil?) is thick enough to be split, surely it cannot be accurate?
Thinner pencil or knife line.
I completely avoid marking with a knife as you can't correct it or erase it when the job is done. No advantage in a precise line if it's in the wrong place!I think a lot of links back to historical methods and traditional tools have their place but the over-riding consideration for me anyway, is what the timber species is, what the joints intended are and what tools or methods best fit the making from a purely practical standpoint. I am the first to admit that I do not possess a plethora of different traditional chisel types and generally only use two: Mortise or bevel edged. I have never had any problems cutting M&T's or dovetails or rebates with these and whilst specialist wood chisels may be designed for specific applications, most can get away with just the two types although I do intend to buy some others. Heresy I know!
Further, the discussions on riding the lines, splitting the line etc are all ones where common sense plays a big part. I never try and split a line when making joints as it's difficult to be precise and where I use pencil lines, often I'll only use a 0.5mm pencil to infill a line cut with a marking knife which is the only precise way of setting a precise line imho, and then try, if sawing the joint, to cut close to the line in one go, including removing the back, then use a chisel to tidy precisely up to my cut line centre. The other advantage I see of using the marking knife is it removes all error when using the bench saw because I can snick the outward facing tooth of an ATB blade such that it precisely locks into the marking knife line and that is more precise than trying to line the fence up by eye along a pencil mark.
Precise yes, but not necessarily accurate i.e. in the right place.I'm wondering if I have misunderstood something from this conversation, Surely, the way to achieve accurate shoulders to a tenon , is to knife the lines. .......
I think they are misnamed and should only be used for cutting a line where you really want a clean edge e.g. on the visible face of a shoulder. Or for making a deliberately indelible line which I've seen on old work, where I guess the foreman has marked up one side from the rod, for the bench hand to complete in pencil.
Then, surely, it is not the knife marks that are at fault, but the measuring. If you knife properly around the shoulders. working off the face-side and face-edge with your square, and using your knife, dug in at each corner, as you go round each corner - then you will have knifed lines that meet. This is all that is required for forming good shoulders. Any inaccuracy, is then down to things not being measured properlyPrecise yes, but not necessarily accurate i.e. in the right place.
Yes. And can't easily be corrected if it's a knife line...... Any inaccuracy, is then down to things not being measured properly
Not saying I can do this but japanese pull saws have a grind that creates a line of alternating points along each side of the blade.
If your line is a knife cut, you can place either the left or right line of points in the cut and start the saw cut either side of your line.
You can do that with a set western saw too. Tilt it into the cut then straighten up as you go. Easier to do it the normal way though!Not saying I can do this but japanese pull saws have a grind that creates a line of alternating points along each side of the blade.
That's all true but there are Japanese saw designs which are backed such as the Dovetail Dozuki made for export markets. I almost exclusively use Japanese saws now because I find them more comfortable to use and they stay razor sharp for a very long time. Their other advantage is the thin blades create less dust, remove very little material and need less energy for each stroke than more traditional western designs.Since the push isn't into them (bearing down), they also will often start wherever you put them. But a little skip at the start of the cut and there's a small but too big mark to remove.
My only issue with them (they're resharpenable, too, and pretty easily) is that if they get off a little bit in a long tenon cut like that, even due to varying wood density or grain direction, it's very difficult to make the small adjustments mid cut that are easy with a back saw.
A thumb or finger beside the blade obviously keeps them from popping up and landing next to the line and cutting on the non-waste side, though.
Absolutely. Layout and marking up from a rod is the biggest time saver and most accurate way of making stuff, even simple one-offs. Seems to be another key technique which is more or less forgotten - perhaps the most important of all.making stuff is not cutting a mortice and tenon. it's making many mortice and tenons. with this in mind the marking out from the rod and transferring onto the components is much more critical than cutting a single joint. all work has tolerance but accuracy on the face and a trim off the back shoulders so they pull up is normal.
