I have done many such jobs making laminated deck beams & other components for boats.
Good prep is essential & nice clean surfaces, you can glue straight off the circular saw but sanding is good.
Always sand a tiny radius on the outer face corner of each lamination, if its a heavy bend & there is the smallest nick in the grain its liable to break at that point.
Dont make your laminations too thick for the bend, more thinner ones means less spring back when you take it off the mold.
Its often good to have a dry run, make sure the mold is strong enough & has enough places for clamps, Set as many clamps as you can so they are ready to be wound up. Nothing worse than having to unwind clamps in a hurry!
Use plenty of brown parcel tape on the mold so the epoxy dont stick to it!
When gluing up start with the bottom one & butter up with a flat stick, dont skimp as a starved glue joint is bad. Too much wastes glue! As each lamination is laid on top of the glue bang a fine brass panel pin in the middle & about a third from the end, stops them sliding about.
When the stack is assembled clamp on the mold in the middle & work outwards alternating sides as you go.
Sometimes the stack will start to twist Or some strips lift, squash them back into line with a clamp.
When done scrape off as much glue as you can.
Top tip, Make sure your mold is well supported, Last summer i had a big lamination job on a boat, kind of a half hoop chine piece for the stern of the launch im rebuilding, section was about 35mm deep & 12 3mm laminations about 8ft long. I laid the mold on my sawbench, glued up & started clamping, halfway round the weight of the clamps over balanced it & the whole lot came crashing over. It was very hot & the epoxy was starting to kick even though i had used slow hardener. Much terrible gnashing of teeth & dreadful swearing ensued as i got the mold back onto the sawbench & this time clamped it down. I got away with it but it was nearly a write off.
I was liberally covered in epoxy! Most boatbuilders will have experienced a similar balls up!
