Hi all!
I recently got myself a 2.8m sliding panel saw in order to speed up production on my cabinet making.
I'm torn as to the best way to rip sheet material into pieces for door stiles/rails etc.
Previously I used a track saw and I've been able to get perfectly repeatable results without any further edge processing (until paint), the downside is obviously the time it takes per cut.
What's the best approach to doing this on a panel saw to get consistency?
Split sheets in half and use the Rip fence? Rip fence with slider? (I use 22mm MRMDF so throwing whole sheets around is challenging)
Rough strips using the slider then use the rip fence?
Rip them slightly wider than required then plane and thickness? (Seems a long way round)
Appreciate any thoughts!
