rogxwhit
Isn't that a small temple?Where I come from it's called a templet.
Not really.
You get the idea if you google - with lots of variations and some confusing explanations.
a joiner's rod - Google Search
Same idea but even more complicated - 12 or 16 pane sash windows or on one occasion a 20 (5x4) you can draw up the rod so that every pane is exactly the same size, knowing that whichever order you do the work everything will fit. You could cut the glass first if you wanted to and you know it would fit.full size drawings( even just the relevant dimensions represented as lines measured from the end) are the way I figure stuff that's a bit confusing in your brain. say you need to make t and g to fit into a door with 5 exactly subdivided planks. ( including some slack.)
Nope. Simple a full size fully detailed sectional drawing, or plan drawing depending on what you are doing. Would include component details and clearance gaps, mortice and tenons etc. You could even pencil in for hinges, fixtures and fittings etcAhh...somewhere between a story stick, project list and template. Makes sense.
Some details might be left out if not needed for the mark up.
Just like the full size drawings an engineers would put together. The difference for woodworkers is that you lay the work pieces on the actual drawing and take the marks straight off
I didn't know there was a different way than this. I got told off getting a chisel anywhere near a tennon.Same here. It is better. Easier to get a straight line as you drop the heel into it from starting at the far side. Neater too - start with a back pull on the far edge and then keep the blade in it as you bring the kerf back. Cut down to the line then turn it, drop the saw into the kerf and finish the cut.
It means that all your cuts are into an existing kerf, and guided by it, and at no point is the saw cutting its way out of the workpiece, with the added risk of spelching out.
Those dudes in the museum are just actors.
Re tenon cheeks - supposing that your marks for the mortice (which you cut first) are spot on with the mortice chisel, and your tenon marks with the same gauge, then saw tenon cheeks, ideally with a rip tooth tenon saw but not essential. Has to be sharp and with a good set so you can keep it on the line - then "split" the line, with a bias towards removing the line rather than preserving it. This is because any error adding width to the tenon makes it a tight fit, small error the other way no problem
