Found a simple 4" length hard wood with a Stanley knife blade bolted into it handy for making out!
What's a rod btw. A stick with all the essential lengths of the cutting list??
Varies enormously depending on what you are making.
For a complicated item like a sash window I'd do what amounts to a full size vertical and horizontal sectional pencil drawing on a board.
A bit of MFC shelving is ideal, and re-usable.
Wouldn't need all the details and might be barely recognisable except to me, but would contain all the details necessary so that you could lay your workpieces on it (cut, planed to size), stacked up if they duplicate, and take marks off with a set square and a pencil. I'd then take each piece individually and carry the marks around the other three sides with a square.
It's a very common and ancient technique used all over the place. Dress makers patterns, sail makers lofts, structural engineers with chalk lines on the floor, boat builders, stone masons arches drawn or scratched on a floor, etc . Everybody's doing it! Or did it.
With hindsight my very first experience was with making Keil Kraft model aeroplanes - balsa wood and tissue paper, which you mark/cut after laying on the printed drawing, then pin and glue them together, on the drawing itself.
It amounts to the final production drawing and last chance to make any design changes to make things fit. Once done you don't need to measure anything you do it all from the rod. All decisions made. Throw away your tape measure (after you have taken off your cutting list). No more long calculations and notes on the back of an envelope. No offering up of one piece to another and transferring marks.
If you do it from the rod they'll all fit - no mistakes!
PS for a door or window the very first marks on the rod would be the basic masonry details of the hole in which you hope to fit the thing.
Also you have to be thorough with face and edge marks and stack opposite pieces with the marks opposite so you don't end up with ten left hand sides and no right handers etc.
