We've lost those on our rack here. I have to admit I had a set of three of those, but then sold them. what I gathered from them (by feel) is they're closer to the 0.6% carbon level than the more "dry" feel on the stones that a higher carbon steel would have.
0.6% carbon steel makes a great tough site chisel (Despite all of the whining people do about chisels like this and the stanley #60 chisels). They'll open a lot of paint cans before they break off (not to mention tolerate being dropped on a hard floor at a site).
HD here has been almost in a race to eliminate anything like that and replace it with something from china (for obvious reasons - I doubt the $7 chisel from china costs HD more than a dollar).
The set of 3 buck bros acetate chisels was only something like $18 at the time - you probably already know this, but there's a "how it's made" on youtube where they don't name the manufacturer but then clearly show the name being printed/stamped on the handles.
(I have a set of site chisels alreay or i'd have kept them. The handles are heavy!...my point about the 0.6% steel is that I think those chisels were probably close to optimized, and while it's too bad they can't hold higher hardness at a sweet spot temper, the steel is exceedingly fine).
https://i1.wp.com/knifesteelnerds.com/wp-content/uploads/2019/05/1000X-5160.jpg?w=750&ssl=1
If I'm right, that link will show 5160 (it's almost devoid of visible particles - actually, that's an SEM micrograph. It looks like clay)
O1 looks like this:
https://i2.wp.com/knifesteelnerds.com/wp-content/uploads/2019/05/1000X-O1.jpg?w=750&ssl=1
1095:
https://i2.wp.com/knifesteelnerds.com/wp-content/uploads/2019/05/1000X-1095.jpg?w=750&ssl=1
A2 (this would represent non-cryo, I believe. I think the carbide dispersion is improved with cryo - but another great benefit to woodworkers with cryo is that terminal hardness is increased by a point or two depending on the steel)
https://i2.wp.com/knifesteelnerds.c...05/A2-cropped-scaled.jpg?resize=768,582&ssl=1
https://i2.wp.com/knifesteelnerds.c...26c3-cropped-resized.jpg?resize=768,580&ssl=1(this is the steel I like for chisels - for some reason, the toughness is double that of O1 - well, mine is - despite higher hardness and plenty of iron carbides. The iron carbides are probably not as hard and don't crack as easily - cracks generally start in the carbides and then propagate out, thus inability to have huge carbide volume and good toughness).
https://i0.wp.com/knifesteelnerds.com/wp-content/uploads/2019/05/1000X-XHP.jpg?w=750&ssl=1
XHP, which is probably the same as V11 or at least very close (I can't discern a difference between V11 and my own irons). The carbides are in neat balls thanks to PM - this steel is made usable by PM and would likely be worse than D2 nonPM without it.
(you've probably seen all of this stuff before, but many here may not have).
When there's a highly alloyed steel (or A2 even though A2 isn't
that heavily alloyed) and discussion o the fine grain is talked about at length, the question needs to be asked "compared to what". The older steels don't have much wear resistance, but their fineness is difficult to better.
With 26c3, I think I can beat commercial heat treat solely because of the level of excess carbide. I am just working in a forge, so resetting and shrinking of the grain is no problem. I *can't* normalize the steel because I'm not a human thermocouple, but that's OK - normalizing would put more carbon in solution (and show fewer carbides), but doing so apparently makes the matrix less tough.
the fact that i can beat commercial for 26c3 is probably a rare anomaly - I would never claim to be able to match commercial in general - you can only do it with a limited set of steels (luckily, I can match furnace schedule results with O1, because it's a useful steel and I have no interest in sending steel out to be heat treated as I think I can do it at least as consistently and if I mess up, I don't have to send it back somewhere to be redone).
Introduce surplus chromium outside of a PM, though, and I'm out. So no ingot stainless steels with excess carbon to form big chromium carbides.
