lurker
Le dullard de la commune
Trim,
Screw fix do wet n dry down to 1200
£2.80 for ten sheets
lurker":3nsvh4ae said:Trim,
TrimTheKing":2vgs716q said:woodbloke":2vgs716q said:the idea being that you can trap sandpaper (aluminium oxide off a roll) under the two side pieces so that it stays flat and doesn't ruck up.
Hi Rob
What paper do you use on this (and where do you buy)? I am in the process of buiding something very similar myself and can only find 240grit on screwfix and machinemart. I would think I need something a bit finer too once I get close to flat?!?
Mark
woodbloke":1vu2lp1v said:Mark - I orderd a set of abrasive papers from Axminster like these which worked well - Rob
tnimble":340zbviu said:You could easily fill two DVDs on tuning up bench planes,
Tony":a6eyljb1 said:tnimble":a6eyljb1 said:You could easily fill two DVDs on tuning up bench planes,
Really? :lol:
Having tuned a lot of planes over the years, i would strongly disagree. Rocket science it isn't!!...
We are taking absolutely basic engineering principles here
alan wood":10rnzhzj said:...
I think if you have a product out there on the market, like all 'producers' you should be open to honest feedback and then looking at improving your product....
David C":2hrdkkql said:There is more to tuning a Bailey plane than just flattening the sole, though this is one of the most important jobs, which is likely to yield the greatest improvement.
