I brought the missus a Hyundai Kona around 3 months ago, the 64kW 2020 model. Like everyone else I was perplexed at the number of different cable types. However my experience of owning and driving a BEV as of today is as follows.
1. Buy a vehicle with a good real world range. Mine has circa 175 cold weather on motorway up to 250 miles warm weather motorway. Book says 278 which is achievable if you drive sensibly.
2. You need several accounts with different EV charging suppliers as not all chargers are tap your card friendly.
3. ZapMap app is a must have.
4. Careful route planning is advisable and factor in 2 alternative stops near your planned recharge stop in case all chargers are taken.
5. Your driving style will dictate your range (efficiency)
6. Weather plays a part in both charging time and range
7. Try to not let the charge drop to below 20%. Don't rapid charge above 80% battery charge. The charge rate drops off significantly once you reach 80%
8. Higher voltage chargers will charge more quickly but cost more. Some as high as 39p kWh
9. Your home charger (mines 7.3kW) will be used for circa 80% of your charging.
10. Get onto a cheap electricity tariff. (Mines Octopus Go) 5p per kWh between 00:30 & 04:30. Car never needs more than 4 hrs to charge to 80%
11. When I work out my cost per mile on the home charger it's very close to 1.1p per mile. Or another way of looking at it is circa 155mpg.
12. The higher the fast charge (max) power the car can handle the quicker the car will charge. Mines 77kW
I've just had the first of it kind in the world all electric charging station opened up a couple of miles from me. Called GridServe. They have the below
- 12 DC Chargers – up to 350kW
- 12 DC Chargers – up to 90kW
- 6 AC Chargers – up to 22kW
- 6 TESLA Superchargers
They charge a flat rate of 24p kWh. So as an example if I took my Kona there on 10% charge and charged to 80% using a CCS 90kW charger it would take 44mins to charge to 80% at a cost of £10.56. Say average range on that charge is circa 200 miles then its around 5p a mile.
GridServe are planning to open 100 EV stations in the UK over the next 5 years.
