Tusses":1f4rc2ho said:for the drum... two mdf circles and some bendy ply ?
Tusses":3s2qnx85 said:for the drum... two mdf circles and some bendy ply ?
some kind of gasket , out of window draft excluder for instance ... the vacuum would help pull the seal tight.9fingers":3osqv0ti said:Tusses":3osqv0ti said:for the drum... two mdf circles and some bendy ply ?
Bear in mind that the collection drum is under suction and if it leaks, the sawdust goes straight into the filter. Avoiding this is the whole objective of the cyclone.
So how brew collection drums need to re-seal reliably after each emptying.
Bob
Tusses":1tt2qil8 said:some kind of gasket , out of window draft excluder for instance ... the vacuum would help pull the seal tight.9fingers":1tt2qil8 said:Tusses":1tt2qil8 said:for the drum... two mdf circles and some bendy ply ?
Bob
We are wood workers aren't we ? :?
9fingers":1n2736k9 said:Yes indeed - it is perfectly doable but wanted non cyclone owners to know about the potential for a problem.
Bob
Tusses":3seaqasg said:9fingers":3seaqasg said:Yes indeed - it is perfectly doable but wanted non cyclone owners to know about the potential for a problem.
Bob
I guess if you use a hose between a wall mounted cyclone and the bin, it really doesn't need to be round. That would make it easier to make, and more efficient use of space .
studders":201b1faw said:They want £40+ for del to me. :shock:
So that's that idea out the window.![]()
