Paul Chapman
And there are other options worth considering. Here are two that I use, both of which avoid the use of a grinder at all.
With a three-stone set-up like this
[/url][/img]
and set-up blocks like these
it's very quick to give the primary bevel a few strokes on the coarse stone, then change the angle and switch to the fine and extra fine stones to hone the edge, finishing with the strop.
The other method I use is basically the same but just use one bevel. People say this takes longer but I find that a few strokes on the coarse stone, then the fine and extra fine stones has the job done quickly.
Given that I don't use water stones so don't have to spend time flattening them, and don't use a grinder so don't spend time setting up that, I reckon my method is probably as quick as anyone's. And I don't burn my blades :wink:
Cheers :wink:
Paul
Cheers :wink:
Paul
