My old blades are slightly bent, they are not perfectly straight. That is why ruler trick helped me avoid a lot of flattening.
I think over time, the ruler trick will cost you time, and when I've tested plane irons, a 0.5mm ruler, or even a 1mm ruler cannot remove edge wear on a dull plane iron without being ground back far enough that it grows.
You're better off if you gradually work the backs flat and then discard the ruler trick - make yourself an iron holder to work the irons if needed, that's my suggestion. If a stone is too slow to do the back work without the ruler trick, it's probably too fine to be practical (the SP 13000 waterstone comes to mind - great to make a tiny very highly polished bevel, but it takes about 30 seconds of continuous use on the back of a tool with directed finger pressure just to remove routine wear - not even considering potential damage or deep scratches).
In terms of the agate stones, they don't really leave a burr because they're not cutting fast enough to leave one. That's something you can take advantage of, but not great if you're removing considerable scratches.
But, when you get the loupe, it will really tell you what you need to know and you can adjust from there.
Part of the reason most sharpening advice on forums fail is the same reason most people fail with the sellers method - nobody can tell what the problem is without seeing it. On a shaving forum, I read all kinds of goofiness about microchipping, and so on and so forth until goading half of the people there to buy a microscope. Razor honing is different, done less often, but has to be done deliberately. Most people with problems have created geometry where the finish stone isn't touching the edge ,and they blame something else - and then a small scope will rat them out and suddenly most of the "defective razors" and other anomalies go to the wayside. Rule number one is the edge has to be finished and damage free, #2 is geometry - everything else is far behind. with a 25 degree bevel, you'll never get damage past the last bevel, so there's no need to do lots of work in the steel above the last bevel. If you find the agate is too slow or difficult to fully finish an edge later, send me a PM with what you have available locally and i"ll make a suggestion. There are a lot of natural stones (like the cretans coming out of greece) that are about half as fine and 8 times as fast, and should be not-so-expensive in continental europe. They can be stepped up to an optical polish with simple honing compound, and they do a great job finishing the backs of tools because they're fine, but fast enough.
