I went to the shop and tried to plane a face of one board. Interestingly, it cut just fine without any gliding over the surface. I did not even need to sharpen once during the face planing. .........
You are not the first to tread this path!
Basically it's about skill, not sharpening.
By the time you've fiddled about with various options suggested by modern sharpen enthusiasts, perhaps bought some expensive kit, you find that you've simply got better at it, even if you go back to square one!
As it happens I found a bit of oak gatepost in my woodpile and couldn't resist having a go:
One stroke with a scrub plane:
This is the mouth of the ECE, I've enlarged it a bit for fatter shavings.
The blade is rounded in both directions! Don't tell anybody!
10 seconds later:
20 seconds later cutting the diagonal the other way:
Then scrub along the grain for 30 seconds:
Followed by a No3 above,
Followed by a 4 1/2 for smooth and flat
About 5 minutes work.
3 planes , all freehand sharpened, no grindstone, rounded bevels, medium oil stone, no fine stone, no stropping, no "ruler trick", squiggle of candle wax.
PS The No 3 has a plastic handles but you wouldn't know except for the seam you can see on top of the handle. Perfectly good quality plane.
