Marcusthehat
From an unbiased users purely pragmatic perspective, see link;
Seemed to be "on the money" to me.
Mth
Mth
Mth
Sounds like you do much the same as I do but on Norton India oil stones and without the diamonds. It works really well and is a lot cheaper - they can last for life in fact!I hope I'm not off topic but a few years ago I acquired 2 heavy, ground 11 x 2 1/2" cast iron plates to try diamond paste sharpening. Together with paste the cost was about $120. I settled on 2000 grit paste alone, using 1 plate. The 14000 grit proved unnecessary as only the polish at the very edge of the tool affected the sharpness. The plate sits in the open, uncovered and exposed to dust which I may or may not remove before using. The blackened slurry from previous usage is removed only if I have to refresh the paste and this is done infrequently. 3-4 drops of oil restore the lubricity and sideswipes for the plane irons, back and forth for the narrower chisels, quickly raise a burr on the backside, which I remove on the same iron plate. The edge is honed with 20 swipes on leather with chromium oxide honing compound, or with 4-5 seconds against a cloth buffer wheel prepped with the same CrO2 or another compound such as Autosol. I credit DW with developing and/or refining the buffing technique. I find it quick and easy to do.
I traded my many hundred dollars of guides and waterstones with their fussiness and variable results for the above faultless process, even in the hands of an old coot. It is an OCD dream to be able to do so. Now if I even think "dull" I sharpen and return to work in 2-3 minutes.
You missed the plate.This idea works for knives, too. I found a banana (carry over comment from the hand work thread).
Practice makes perfect!You missed the plate.
Mostly because nobody is actually making anything and sharing it in this section.Oh FFS - why do people keep on banging on about sharpening?
They never did in the past. Hardly gets a mention in the old books - just simple advice for beginners in a paragraph or two. Even the old magazines (written for amateurs) never went into great detail. It was taken for granted that any fool could do it!Oh FFS - why do people keep on banging on about sharpening?
Well there you go!I like to chop bits off planks of wood for fun and when my chisels and other stuff get a bit blunt (and I don't like the look of the bits that come off any more), I rub the blade up and down on a Diamond thing until it looks a bit shiny on the end......, then I remembered watching an old chippy who used to slap his chisels sideways on an old chunk of leather, so I did that, too.
It worked!
They chop bits off planks again!
Took all of 40-odd seconds.
I can’t believe how complex all that was and the ‘magic’ behind it is way beyond me.
But, I prefer chopping bits off a plank with a chisel more than rubbing it up and down on the Diamond thing.,
It worked!
Platitudes don't amount to much.They never did in the past. Hardly gets a mention in the old books - just simple advice for beginners in a paragraph or two. Even the old magazines (written for amateurs) never went into great detail. It was taken for granted that any fool could do it!
Begs the question - did they know something which has now been forgotten?
I think not. It's more that we are being misinformed by armies of maniacal enthusiasts new to the craft. They have struggled with it, everybody does at first, but reacted by inventing ever more ludicrous theories and expensive ways of doing some very simple but essential things.
I don't know what an old chippy is, but maybe a site worker?
A 'Chippy' is
- A chip-shop - uniquely a culinary venue that sells fish and chips. (Not one of these at all, in this context).
- A Carpenter. Often found roaming in the wild on building sites, but can exist in a variety of habitats. The traditional British variety is often seen with a cup of tea in his hand, a pencil behind one ear with a roll-up, dangling as he speaks.
