Adam W.
A Major Clanger
looks like it's Leicesters day
But not D-W's
Second half..... can't see Leicester winning this one.
I agree You didn’t say it’s the “THE CORRECT WAY” but your phrasing did.I've never ever said anything about “THE CORRECT WAY” it's not what I think. What I have said is the easiest, quickest and cheapest way. That's all really. Don't know why it's a problem.
He probably gets as close to what he wants in the time he’s prepared to spend.don't worry - jacob has never shown a picture of a particularly crisp edge, so it's not like he's sitting on some big secret.
What is important is getting an edge that is good enough for the work you do and lasts a reasonable time.
Brilliant
Actually I do think it would work for anyone but they have been talked out of it!........ but don’t imagine that your skill that you constantly practice works for everyone
It's not highly skilled at all - it's basic and simple.
But don't worry about it do it your own way - just be aware that there is an alternative!
Get one of your old wide leather belts, chop out the middle piece to use, attach it, unfinished side out, around a piece of 2x1, job done. Made mine from my hubby's belt back in college and still using it to this day. The sharper the tool the easier and safer to use. As for sharpening, I was the same, it's just practice.I have already tried the latter.
Tbh I have always looked at the leather strops as being a bit unnecessary, like.. who needs it THAT sharp? I should get one and find out for myself though I suppose.
Mines a bit of handbag leather. I cut it from a bigger piece which I kept in case this one wears out. Still got it, 50 years on!Get one of your old wide leather belts, chop out the middle piece to use, attach it, unfinished side out, around a piece of 2x1, job done. Made mine from my hubby's belt back in college and still using it to this day. The sharper the tool the easier and safer to use. As for sharpening, I was the same, it's just practice.Over time I developed my own technique, preference on bevels and angles of bevels for certain jobs. I inherited my grandad's & dad's chisels. The old steel takes an unbelievable edge but I need to hone/strop more often, the edge on my own newer chisels, (just over 30 years old,) keep the edge longer but never as sharp as my old ones. Carbon content makes a difference. Buy an old one from a junk shop & try it. You'll get there, it's just practice, trial & error. I've ended up with some wonderfully weird shapes & angles over the years, the penny will suddenly drop.
Best thing with oilstones is to not flatten them. Flattening and lapping are two notions which came over strong with modern sharpening. Instead, as you work just spread the load as evenly as you can.Trying to flatten my oil stones can be interesting. All my oil stones are pre-owned and had channels and valleys and cups worn into them and I spent more hours than I care to think about flattening them. It is worth it in the end though because I especially like the oil stones for my adzes, axes, and drawknives. I always use my waterstones for chisels, plane blades, and similar. Right now I'm trying to figure out if I need a diamond plate to lap my waterstones. I've gotten this far without one (I've used a ceramic bathroom tile for ages) but I hear good things about some of them. Trying to justify the price though.
Bet your mum was chuffed!Mines a bit of handbag leather. I cut it from a bigger piece which I kept in case this one wears out. Still got it, 50 years on!
Was that what you were thinking about when you got his trousers off?Get one of your old wide leather belts, chop out the middle piece to use, attach it, unfinished side out, around a piece of 2x1, job done. Made mine from my hubby's belt back in college and still using it to this day.
Was that what you were thinking about when you got his trousers off?![]()
