Sgian Dubh
I'd rather not. I can't be bothered with all the dicking backwards and forwards after I say my piece. Slainte.Do it...
Do it...
Do it!!
Do it...
Do it!!
Ah, okay, you've sort of forced me into declaring my hand, but everyone has to bear in mind that there's nothing clever or innovative about my method.Work the back of the tool first on something pedestrian like an india stone, then work the bevel, then work the back again and strop.
The jig thing for me was nothing to do with chest beating - I just found it all so much faster/easier without, though it took some time to rediscover this simple fact.....I have to admit I've never used a guide, but I'm not against guide use if that helps others to achieve success. I've just not used one myself, but that's probably because not a single person in the workshops I started out at used one either: and if I'd ever got one out I'd have probably been jeered at and called some kind of effeminate limp wristed pansy, or worse, along with other mildly humiliating name calling accompanied by somewhat irritating and underhandedly secretive sabotage of my work or toolkit. That sort of stuff was considered gentle workshop banter back then in the dark ages, but it probably wouldn't translate well into our more recent caring and inclusive times, ha, ha. Slainte.
Absolutely right. I wouldn’t be without my Stanley Nr4's, I use virtually nothing else. Fettled a good bit of course.I like india stones. Quite often, the pedestrian stuff is better than the snooty stuff. The pedestrian stanley 4 is probably the best smoothing plane ever made.
But, it's basically as you say, i.e., start with the flat side of the tool (bench chisel or plane iron) and work that a bit making sure I keep the tool flat on the stone, for which I use either the fine side of a combination oilstone or my 800(?) grit ceramic stone, whichever is to hand, then work the honing angle at a guesstimate of about 30º, then go back to the flat side again to take off the wire edge, and finally a few back pulled strokes alternating between the honing angle and the flat side, and then a bit of flipping of the tool on the palm of my hand. That's good enough for 90% of my sharpening, and I never do anything more than this for regular bench chisels.
If I want a plane iron especially sharp for a particular task, I omit the palm flipping just mentioned, and repeat the procedure above on my ultrafine ceramic stone, and nowadays (based primarily upon your writings on the topic) I stick a polishing mop in a drill, add a bit of polishing compound if needed and give both the flat face and the honing angled side a swift five or ten second buff each. It seems to work pretty well.
I like to keep sharpening of my chisels and plane irons to the 'Sharp'n'Go procedure, aka the KISS principle, and I have to admit I've never used a guide, but I'm not against guide use if that helps others to achieve success. I've just not used one myself, but that's probably because not a single person in the workshops I started out at used one either: and if I'd ever got one out I'd have probably been jeered at and called some kind of effeminate limp wristed pansy, or worse, along with other mildly humiliating name calling accompanied by somewhat irritating and underhandedly secretive sabotage of my work or toolkit. That sort of stuff was considered gentle workshop banter back then in the dark ages, but it probably wouldn't translate well into our more recent caring and inclusive times, ha, ha. Slainte.
Fair enough, you can't help yourself.I like india stones. Quite often, the pedestrian stuff is better than the snooty stuff. The pedestrian stanley 4 is probably the best smoothing plane ever made.
Maybe you should just call a spade a spade instead, then people wouldn't take it the wrong way.
If you do the ply disc thing it helps to have an artists palette knife to spread the autosol. Nothing else is quite as effective. You spread it thinly and keep picking up blobs to spread, or it gets flung off the disc. Slow speed is good.Thanks Richard and Jacob, although I’ve never felt the need to strop I think I can manage a bit of plywood on the end of my lathe, i’ll give it a try, says Ian as if he’s being sucked into the maelstrom of sharpening wizardry and expecting to be spat out broken and twisted and full of the Evangelical zeal that inhabits large proportions of the woodworking fraternity.
If that's what you were doing during your campaign door knocking it's no wonder you didn't get a result.It's OK I was only joking.
Gone a bit quiet over there maybe I should pop over and wake them up - shout "WAKEY WOKEY" through the letter box or something?
I am bad at sharpening, and have undertaken making a dovetailed box, which by the time it is complete will require me to have become "passable" at sharpening.
I have 600, 2000, 4000, 8000 grit wet stones. I can freehand a bevel on the 600 grit that feels sharp, but when I step it up to the 2000 grit with a microbevel, it appears to dull the edge more than sharpen it.
I'm rather hoping this is a well understood boo boo that I'm making and somebody can give me a clear instruction for how to, um, not do it. I have of course read many instructions, and watched many videos on the topic, but the skill still eludes me.
Yeah, tell me about it. I have a honing guide and I usually use it but sometimes I cannot readily find it so on those occasions I sharpen freehand.If I had a honing guide, I'd never be able to find it.
I've got two in a drawer. I can honestly say I have not used either of them for years but I know where they are. Well where they were last time I looked.Yeah, tell me about it. I have a honing guide and I usually use it but sometimes I cannot readily find it so on those occasions I sharpen freehand.
It remains a mystery how I can find my sharpening stones yet not find my honing guide. A related mystery is how I later find the guide just next to my stones.
