Ttrees
Iroko loco!
A true co-planar adjustment now
And accurate wheel alignment thereafter, don't pinch the shaft when doing adjustments,
I've wrote a bit more on that elsewhere, basically a north or a south needs loosening,
in order to adjust the east or west jacking screws.
Motor pulley depth checked, new belts can have a lump at the join to throw you off.
Need better lighting, (the camera doesn't like that)
Turned out there's no such thing as flat tires, this Centauro tire from the dealer,
was infact crowned, and the apex was 17.5mm from the front edge.
There's 1mm between the centre of the tire, and the actual crown,
which could make the difference if running extremely narrow blades,
regarding wiping out the crown, and things going wonky.
Just cuz they might appear flat at first glance, when in a circumference,
this is certainly not what the blade feels.
a thicker block as to align it with the wheels on two axis
Just a mock up shot, showing some saw plate, but what's missing here is the suitable blade installed in order to keep the
upper wheel from tipping, and the beam for making the it co-planar.
Not doing so, can wipe out the apex of the crown very quickly,
and to make note once the apex is dressed enough to be concentric, then
one can remove enough material from the tool, as not to take off any more than needed.
![Screenshot from SAM_7975.MP4.png Screenshot from SAM_7975.MP4.png](https://cdn.imagearchive.com/ukworkshop/data/attach/150/150676-Screenshot-from-SAM-7975.MP4.png)
![SAM_8082-02.jpeg SAM_8082-02.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/150/150685-SAM-8082-02.jpeg)
![SAM_8082-01.jpeg SAM_8082-01.jpeg](https://cdn.imagearchive.com/ukworkshop/data/attach/150/150684-SAM-8082-01.jpeg)
