We had three objectives for our redesign of the S45's tension mechanism.
1. To achieve the tension recommended for the widest (20mm) blade that the saw is specified for when using M42 blades, nor just carbon steel.
2. To be robust, easy to use and to add in stops to prevent over compression of the springs and the damage that results from this.
3. To keep as close as we could to the original look and feel of the saw.
It's time to let you all decide if we succeeded
As a reminder, here is the two part pressed steel assembly that carries the upper wheel, tilts it for tracking and allows 30 to 40mm of vertical movement. In this image, the two parts have been opened like a book so that you can see the inside. Here the narrower fixed part is on the Left, the moving front part on the R.
Here's the modified assembly for the upper wheel laid out like an exploded diagram:
We have left to right:
The original tension knob
A new alloy disc with a groove cut and black filled for reading the tension
A new clear tube on which the tension scale will be applied
The original steel base of the tension scale
A new 10mm threaded rod and nuts
A new ball bearing thrust race to reduce friction when tightening and slackening the tension (boxed)
A new floating plate with guides for the outer pair of springs
A brass sleeve for the centre spring
Three new springs. These are part G25-089 from Berger tools. 25mm OD, 12mm ID, 89mm long and the G represents a specific family of heavy duty springs made from rectangular section wire something like 4×5mm cross section. These springs are conveniently colour coded. There are a few families of less strong springs and just one heavier grade but the yellow ones were a nice fit for the job. They cost less than £5 apiece.
Modified original backplate.
Here are the new springs installed in the back plate (this time on the right), and the modified front plate (left).
On the L, the welded bracket was originally higher up. It has been cut out, ground back and a new bracket milled, tapped and welded in place lower down.
On the R, three springs sit on a new welded in shelf.
A floating bridge piece rests on top of them.
Both of these plates have an oversize hole in the centre for the tension rod to pass through.
A brass sleeve protects the middle spring from the threads.
Guide rods keep the two outer springs in position. These springs are 89mm long so to limit compression of the springs to 25% max, the guide rods project 89-22=67mm.
Two nuts are locked together to form a fixed stop on the tension rod. When the springs are compressed, the bridge piece pushes upwards, force passes through the thrust bearing onto the stop and pushes the rod upwards. When all is assembled, it's this upward force on the rod that pulls on the upper wheel and tensions the blade.
To assemble the bracket, the upper wheel is first refitted to the front part of the bracket, this is then placed over the back part and the tension rod screwed into the lifting tab to take it's weight.
A cross pin fits through two slots that allow about 40mm of vertical adjustment
This is secured with washers and circlips at each end.
At this point the upper wheel assembly can be bolted into the saw.
To finish off, the components for the tension indicator are threaded and screwed onto the tension rod.
The black line provides a definite index mark for reading the scale. Previously there was just a thick washer and no information about whether you should take the top, middle or bottom edge of the washer as the "pointer". SCM told us that we should use the bottom edge of the washer to read the tension and avaoid over compressing the original single spring, but that isn't explained in the instructions ...
As we have changed the springs, the old scale isn't relevant anymore. I'll draw up a new one based on the combined spring rate and this will be printed on clear film and applied around the clear cup.
By keeping to a 10mm tension rod, the original knob screws neatly on top
A comment on the finish. Obviously grinding and welding on the metalwork affects the plating applied to these parts in manufacture. We can't practically replicate that but we do want to protect the metal afterwards. The brackets here have been degreased, given two coats of high zinc content cold galvanising spray and sealed with silver aluminium.
