MorrisWoodman12
Minimal for the equipment I worked with. I would guess the same for a motor apart from rpm.
In this case nothing because the VFD controlling the motor will contril speed, but on a generic induction motor, they run about 20% higher rpm at 60Hz vs 50Hz.what is the effective of the Hertz?
so as 60 is 120% of 50, would a machine designed for 60hz be 20% slower run on 50hz or am I just being too simplisticOne point to remember, whilst the USA and Canada have a 110v system they do also have the ability to supply 240v for certain higher power needs, this I suspect what the lathe is designed for. Now the question is would a motor designed for 240v 60Hz run ok on out 230 (ish) 50Hz supply. I suspect possibly yes but it may run a little slower than expected due to the lower frequency.
No expert though so more research will be needed
It is a Oneway.The designations here are nominal, not absolute. I took a walk around the shop and the different motor data plates are marked with 208V though 240V (110V/115V/120V for lower voltage stuff) and they all run fine on whatever the power company is supplying. The 240V won't hurt the lathe. What kind is it? A Oneway or a General?
I envy you as I do with about the ten or so in our turning club that have them. Someday.It is a Oneway.
120 volts can be lethal as it is sufficient to drive the required amps through your body, the reason why we used 110 - 0 - 110 for sites and safety is because there is only 55 volts to ground.This setup was considered safer for domestic use as a jolt of 120volts is sub-lethal.
AC has been used simply because that is all that you can generate and the voltages can be steped up or down using transformers but now with modern semiconductors Dc is offering some major advantages such as easy interconnection of networks because there is no phase to align and is very efficient over long distances with less wires. Currently you need three sets of wires per three phase circuit and often two circuits are carried on the pylons so two sets of three wires. If you look at how the Chinese get the power from the three gorges hydo plant to one of the provinces they use a Dc system of plus 500,000 volts to minus 500,000 volts over a distance of over 900Km and a capacity of 3000,000,000 watts.The disadvantage of DC power is there is a lot of voltage-drop over distance
You mean an RMS value which gives an AC power rating that is equivalent to a Dc system, ie 1 volt Ac RMS across a 1 ohm resister gives 1 Watt of power the same as 1 volt Dc across 1 ohm.All this is purely notional, as the actual power supplied is something to do with a "root-mean-square" calculation, at which point I drifted off, but the result is that 240v isn't actually 240volts, it just behaves as if it is
In North America homes are wired with both 115V and 230V (nominal) single phase. The 115v is used for most things like lights and wall receptacles. The 230V is for the larger loads like the stove (cooker), clothes dryer, water heater, electric furnaces and baseboard heaters. Any shop machine over 2 hp is usually run on 220v. A lot of the smaller machines can be wire for 115V or 230V. Since P=IV ( power= current in amps times voltage then as voltage increases current decreases for any power level. Less current = among other things, less heating. The higher voltage means less heating. The insulation should be able to handle the slight increase in voltage.Photo of the motor rating plate ?
Canada is 120v 60Hz mains as I understand, so it may be a white Canadian Oneway lathe factory fitted with a 220v motor for export. Oneway were imported into the UK for many years but no longer.
A motor rated at 50 and 60hz has some margin in it as the power is higher at 60hz. From a heat and dissipation point of view only, slightly high voltage will be offset by it being used at the lower frequency.
It shouldn't. You're the smart one for asking the question and taking advantage of the resource available to youWe have a lot of knowledgable people on UKW ,
Makes me feel inferior
That!It shouldn't. You're the smart one for asking the question and taking advantage of the resource available to you
Black magic, as previously stated.120 volts can be lethal as it is sufficient to drive the required amps through your body, the reason why we used 110 - 0 - 110 for sites and safety is because there is only 55 volts to ground.
So if you take the 240 volt RMS then this equates to an Ac peak voltage of 240 x square root 2 = 340 volts.
Will be fine, i brought my 240v tools over from UK to Canada and run off 220v here. Hertz is higher here (60 vs 50hz) but again it doesnt seem to have any impact. Maybe if you measured it, it could run marginally faster but honestly you cannot discern it. I have run my UK 240v tools over here for 3 years now without issue including lathe, air compressors, sanders, drill press, planer thicknesser etc.It is a Canadian lathe , shows 220 volts on the machine.
That is meThat!
“If you’re the smartest person in the room, you are in the wrong room.”
Hello BlisterThat is me
No, Sadly I parted company with the Titan.Hello Blister
Do you still have the Titan?
Speaking as perhaps the only Titan owner in western Canada .I can’t see you going to a Oneway after the Titan as I’ve turned on both .
Thx dk
