AES
I'm surprised to, seems done on the cheap to avoid the need to step down the voltage. It appears to connect the motor directly to the mains for up to a quarter of the mains cycle, it's that duty cycle which allows a 60V motor to be used (240 ÷ 4 = 60V).
I've sketched out how it seems to work in the attached photo, connect it to mains for only e.g. the rising portion of the positive half of the mains cycle.
However that has some drawbacks. The power factor will be utter rubbish. The saw will need to make at least six strokes up and down carried by it's own momentum, even at the lowest speed. More significantly the entire circuit is exposed to peak mains voltage, insulation including motor windings need to accommodate that. The same goes for the speed controller pot - there will only be some lower voltage across it along with the rest of the control electronics, but regs state it should be a safe condition even if live and neutral are reversed, I suspect it would actually be at the mains voltage level in that case and I doubt it is mains rated.
Curious now, going to have to hang a scope across the motor on my Diamond to see if it's the same...
If the supply to my machine looks like you've sketched it ajs, then I'm VERY disappointed. At the price point of this machine, I expected full wave rectification! (See my post above).
