It could be a failed capacitor (usually a large one) that is designed to smooth out the DC after rectification. They can short out internally which would wreck a fuse holder after a few attempts to start the machine again.
That would be very helpful, thanks.So when complete shall I post all the dissassembly info here (on the Scrolling & Scroll Saw Section)?
@AES do you have any updates on this yet?UPDATE. Monday 16th Oct:
SUPPLY:
I now have all the info needed from Dictum in Germany:
The price of the PCB is €125.97 and the fuse is €4.12. Courier delivery is €13.40. Items are both available on the shelf for immediate delivery from Dictum.
BUT: Dictum seems to have changed their rules: They will only accept credit card payment if you live in Germany. For everyone else payment is by Proforma Invoice (i.e. you pay, then when they get notification of payment from their bank they ship the goods). But at least you get a 2% discount on the total value of the goods if paid within 10 days of Proforma Invoice date!
Their Invoice will be paid today, so even with this delay I expect to have the goods in my hand within 7 to 10 days.
A couple of points for anyone in UK thinking of buying from Dictum (as Germany is EU whereas neither Switzerland nor UK are, so I expect the following will apply more or less equally):
The courier will charge me a Customs Clearance charge ("admin fee"). Based on past experience this will be excessive and bear NO relationship to the actual "work" involved in clearing the goods through Customs (I have done that myself in several countries quite a few times and with the right paperwork - i.e. a Proforma Invoice and Customs Ref Nos for the items, - it's no problem, AND goes pretty quickly too). AND the courier charges are NOT related to the value of the goods either.
In other words it's just a con - IMO anyway! But one has no choice except pay up!
AND Swiss Customs MAY also charge Import Duty (my experience here is mixed - sometimes they do, sometimes not). When I know what these extra costs are I'll post details.
THE MACHINE:
I'm STILL working out how to get the PCB out! I cannot see any reason why I need to remove the motor itself (from the spare parts diagrams in the Manual nothing shows) but I still cannot get the "Control Cover" off to get the PCB out. I've done a lot of online searching about changing the PCB on the Excalibur (and on similar machines) but though I found several pix of the PCB itself, NOTHING found on getting into the machine to remove it.
So I'll be going onwards with that today. First I'll need to make up a "special tool" to lock the motor solid while I remove the nut holding the motor spindle onto the eccentric drive.
More later .................
Good luck and fingers crossed the new pcb is the fix
Is it possible to post your tome into the How-To's section of this forum. Mind you I don't know how-to do that.![]()
I'm surprised to, seems done on the cheap to avoid the need to step down the voltage. It appears to connect the motor directly to the mains for up to a quarter of the mains cycle, it's that duty cycle which allows a 60V motor to be used (240 ÷ 4 = 60V).Much truth in that.
That board is doing less work than the variable speed control built into the trigger of your power drill and the tech is about as old as I am !
Oddly, about the only positive justification for sticking with something that dated would be to to make it easy to replace a component![]()
