240 volts into a 220 volt machine ?
The photo shows a control box of a premium lathe with mention of an inverter.
Unless modified, this lathe is driven by a variable frequency drive.
The motor then doesn't matter. The electronics will take care of that.
The input voltage range of the VFD is all that matters and they won't care whether 220 or 240, 50 or 60Hz.
Crack on and use it ....
One point to remember, whilst the USA and Canada have a 110v system they do also have the ability to supply 240v for certain higher power needs, this I suspect what the lathe is designed for. Now the question is would a motor designed for 240v 60Hz run ok on out 230 (ish) 50Hz supply. I suspect possibly yes but it may run a little slower than expected due to the lower frequency.
No expert though so more research will be needed
so would as 60 is 120% of 50, would a machine designed for 60hz be 20% slower run on 50hz or am I just being too simplistic
edit - sideways answered my question whilst I was typing, sorry
The designations here are nominal, not absolute. I took a walk around the shop and the different motor data plates are marked with 208V though 240V (110V/115V/120V for lower voltage stuff) and they all run fine on whatever the power company is supplying. The 240V won't hurt the lathe. What kind is it? A Oneway or a General?
It is a Oneway.
