WIP Competition Entry "Chess Table" FINISHED
Fitting the top
With a long phillips screwdriver going right through the drawer cabinet I'm marking the top where to drill pilot holes.
Applying the finish
Top attached and first coat of danish oil applied.
Taken outside just to show the true colours
The finish of one coat of cellulose sanding sealer cut back with 0000 wirewool, Then two coats of danish oil both cut back with wire wool, lastly a thick coat of paste wax (Black Bison) applied with wire wool then buffed off with a clean cotton cloth.
With the Drawer Open
Check Mate
The Last Picture
How does the drawer open, push to open? perhaps this is mentioned earlier? Otherwise a lovely piece of workmanship, it may be easier for somebody else to do the chessboard part with veneer, if they fancy having a go at copying your project :wink:
Thankyou LN, I've really enjoyed watching this come together and, as usual, I've learned a lot. A truly lovely piece of work :).
Boz
I have bought some very small bronze knobs to fit but I'm undecided whether to fit them and as the drawer is right through it's no problem just to push the drawer whichever way.
Bloonose":y3jx33ps said:
A lovely piece of workmanship, it may be easier for somebody else to do the chessboard part with veneer, if they fancy having a go at copying your project :wink:
I think the method I used is easier than doing veneer, I did think about using a veneer especially because of the cross grain situation, and because of that I kept the checqured area as thin as posible it was less than 1/4" before it was totally glued to the mdf.
My compliments in addition to above remarks, perhaps one day we can pop down and have a game on your table.
(I would have to read up on opening gambits again etc.)
Very well done indeed, it looks flawless. :) Makes me feel like it's not even worth me starting my competition entry, having seen this now!! :D ...I think I know where my vote may be going! :wink:
very nice LN - one point , i had envisioned that you would have had a little compartmented drawer to take the pieces - any reason why you decided against that ?
Those finished pictures should come with a sound clip of someone hitting a high soprano note.
Super!
big soft moose":6e8wughu said:
I had envisioned that you would have had a little compartmented drawer to take the pieces - any reason why you decided against that ?
I still might do that by adding a lightly made frame inside the drawer, a bit like a noughts and crosses grid.
I think there are quite a few including yourself who rather than post a WIP thread are going to mind blow us with the high standard of their finished entries, lets just say there are a lot of dark horses out there. :wink:
OPJ":2tg373qq said:
Having seen this now!! :D ...I think I know where my vote may be going!
:shock: Is it not down to the judges, who have to keep quiet :lol:
I'm sure your table entry will be a worthy contender you little dark horse you.... :lol: :lol:
Addendum to the chess table drawer
So I decided on making a divider for all the chess pieces.
Here in this pic I've knocked up a jig to use a 6mm cutter to slot all the wood, the wood is all 6mm thick.
All the pieces cut and ready for a dry assembly.
How it looks assembled dry.
Fitted in the drawer still unglued it was obvious that it need not be as deep.
So I ripped 1/2" off the depth, here still unglued I'm trying it out for size.
The grid in this pic is glued up but not glued to the drawer, however the little blocks you can see in this are glued to the drawer, these are to hold all the chess pieces level.
Next step is to remove the grid and flock the base of the drawer.
For those who are unaware of flock here is a box I made some time ago using flock to line it. In this pic the box was still unfinished.
