Calum Bettison
With the MFT box sat in situ I gave it a couple of coats of OSMO. To be fair MDF doesn’t look completely unattractive with a bit of Osmo!
Cheers Ian, a lot of planning for sure. The design is an exploration more than a confident idea. I know I have a tendency to over complicate things sometimes, but I’ve tried to keep clarity of concept for this design. Hopefully it will at least do a lot of things I need it to do.I’m not an MFT sort of person but I can tell when something has been planned and well made. The Beech side of things and the underframe I can say from experience is really very good indeed!
It’s normal for a woodworker to make a few benches over a lifetime using the experience of the previous ones, so it will be interesting to hear what you think in a couple of years time about the two sides of the bench.
Brill work.
Ian
As its a work top, i would think you'd do a bit of sanding there.Hello all, thanks for all of the input and apologies its taken me so long to respond!
Before I posted my initial post, id done a few design sketches but since then taken a few steps back.
I've had a proper good look at the 3x3 custom, Hooked on wood, and Pedulla studio YouTube benches to steal some ideas and general inspiration. Also taken on board the generous advice from your kind selves.
For the sake of reduction and simplicity I've removed one of the main elements being the router table. I do use a router table quite regularly, but as a function, it felt like it was battling with the trad bench aspect too much. Clearly they're very different beasts and trying to combine them was just forcing things not meant to be together.
Of the YouTube workbench designs ive seen, the 3x3 custom one built by Tamar looks great. Way too fancy for me and my budget but definitely a good start point to work from.
What I feel suits my needs is the simple split of the two bench styles. So with that in mind Ive drawn up a preliminary design.
Main design elements:
Thanks again for everyones input its very much appreciated! It might be slow progress as I have a lot on at the moment but I will deffo post updates of how I'm getting on.
- Trad bench-
- Probs beech, maybe ash? Affordable hardwood ideally
- 280 x 1800 x 100 thick
- Big 500mm front vise (sacrificed a proper tail vise for now - router table will be in the way making it inaccessible - I can use one of those small dog hole ones until I get more space)
- MFT -
- Plain old MDF
- 480 x 1800 x 100 thick
- Making a torsion box for rigidity and flatness. The top sheet will be fixed down mechanically so when it becomes knackered I can put a fresh MFT sheet on top.
- Apron to help with assembly (only partial width so I have access to tool shelf )
- Cross cutting -
- Benchdogs fence seems to have plenty of great reviews - happy to go with that
- Rail hinge? or maybe rail clips unsure just yet, probs come down to cost
- Base -
- Softwood - larch, Doug fir, also considering something cheaper like constructional grade pine?
- Big open shelf for quick access to tools (plenty hight to accommodate festool track saw for cross cutting sessions etc)
- Will put drawers in bottom, just not drawn up yet
- Festool extractor lives under overhang and can be pointed to either side easily
- Router table -
- Doesn't live in the bench, but planning to build one and house it at the end (the non-overhang end) - the reason for non-overhang is so I can securely but removably bolt/clamp/however the router cabinet flat to the workbench to increase sturdiness of everything. But can remove if necessary.
Also any feedback or advice on my current design is more than welcome!
Cheers,
Calum
View attachment 170419View attachment 170420View attachment 170421View attachment 170422
Hey Andy that could be a good shout. And maybe something I could retro-fit. I am fortunate though in that I have access to another workshop space where there is a decent through draft to take care of any lingering dust.As its a work top, i would think you'd do a bit of sanding there.
What about adding a downdraft section to the table ? I know its probably not the type of thing any would have thought and probably tricky to install even if the holes did line up. But came across it again the other day researching "Anything to keep dust low" and wondered if it could be retrofitted into an mft im building.
Im using the Ujk frame,, so i've got room below it to fit some sort of sealed section.
https://www.axminstertools.com/axmi...utm_content=2266&tagrid=63158213&glCountry=GB
Ha I did think about it, would certainly have been a lot quicker!Oh good you’ve done it right, none of this mounting it proud nonesense.
Those things are called Webbs or sometimes ribs btw.
You might want to consider fitting a planing stop whilst the top is off?
Cheers Martin. There’s a lot of faffy detail I’ve not included in the thread too, mostly because I was cracking on and forgetting to take photos.Very interesting thread to follow. Loving the planning and attention to detail.
Martin
Thanks for the link, I did consider these and was about to go for them but then thought about how infrequently I’d need to move it.It's going to be a fabulous workbench. What are you planning on making on it?
BTW, if you ever want to move the workbench, these retractable castor wheels are quite neat, and the feet adjust to the floor:
4pcs GD-60F 3.2" Industrial Casters Plate Casters Swivel Wheel Retractable Leveling Castor Load Capacity 551lbs
https://www.amazon.co.uk/gp/product/B07SCXSFDC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Those particular ones are now "unavailable", but Amazon suggests similar alternatives, and even higher weight ratings. Perhaps not suitable for vigorous planing, but I have some and they are sturdy.
Shortened working life with respiratory complications. Leading to a premature demise.Hey Andy that could be a good shout. And maybe something I could retro-fit. I am fortunate though in that I have access to another workshop space where there is a decent through draft to take care of any lingering dust.
I honestly don’t know how people back in the day could work without a mask![]()
