Jacob
What goes around comes around.
Just keep them in poly bags. Pack them on a dry day, cold if possible. Seal by turning over the tops and holding with clothes pegs or similar.
krismusic":nbd26dwd said:I am still thinking of building a large insulated box inside the lock up.
Would I want to keep a through flow of air or seal it up? Kris
I'm not quite understanding the logic behind insulation boxes. This is my thinking (which I assume is missing an important point) - if the tools are air sealed, and the air inside is dry, then there's no moisture inside to condense, so it doesn't need to be insulated. If it's not air sealed and fully dry, insulating it will just slow down the speed at which the air and objects inside change temperature, it won't actually stop the contents going below 0. So any moisture inside should still condense on the metal. Is the idea that the insulation slows down the cooling enough that during a cold night the contents haven't fully cooled before morning, at which point the ambient temperature increases again? So while the contents will get cold, the peak won't be quite as low as if uninsulated?tekno.mage":nbd26dwd said:You'd want to seal it up if you could - but that might be more difficult to do than sealing tools inside individual boxes. This is one instance where ventilation is not desirable (assuming you put your tools away dry and not even slightly damp!) as ventilation brings in outside air at it's ambient temperature and it is temperature changes that cause moisture to condense out on metal objects.
Triggaaar":2ljc10ai said:I'm not quite understanding the logic behind insulation boxes. This is my thinking (which I assume is missing an important point) - if the tools are air sealed, and the air inside is dry, then there's no moisture inside to condense, so it doesn't need to be insulated. If it's not air sealed and fully dry, insulating it will just slow down the speed at which the air and objects inside change temperature, it won't actually stop the contents going below 0. So any moisture inside should still condense on the metal. Is the idea that the insulation slows down the cooling enough that during a cold night the contents haven't fully cooled before morning, at which point the ambient temperature increases again? So while the contents will get cold, the peak won't be quite as low as if uninsulated?
I'm thinking stopping warm air getting in is the most important thing. If it's been cold, the contents will all be cold (even with insulation), and if warm air gets in the moisture in it can condense on the still cold metal. I'm not sure how much insulation will prevent that :duno:tekno.mage":2pc4pbjm said:The purpose of the insulation is to slow down the rate of change of temperature of the air & objects inside the container and hence avoid the condensation. If the metal object inside is the same temperature as the air around it (ie the insulation has providede a nice little microclimate inside the box) no condensation should occur.
Triggaaar":1vmcl4nj said:Buildings require insulation, heating and ventilation, so I'm not sure why a storage box can get away with just insulation. Sealing them with a silica gel pack seems like a good idea to me.
krismusic":2cjm6xus said:Kym, you have obviously given this subject a lot of thought and have a lot of experience.
I will definitely take what you say on board.
One problem is finding large enough airtight boxes for the machines.
I prefer this idea to greasing the machines as there will be areas that it won't be possible to get to and then there's the motors...
krismusic":3ofgdwjy said:Hmmm. Thanks for the replies. I like the idea of treating my tools like swords! :twisted:
Basically if it is likely to require fairly extreme measures to stop my tools deterioraHmting I don't think I wl put em in there in the first place. :| some of those ideas could be very practical for fixing and fittings though. Maybe cool boxes as they seal... Thank you very much for your thoughts. K ccasion5:
That's brilliant. I am in London so not local but thanks very much for the offer. Presumably I will find silica packs online. One thing about silica packs. How long do they remain effective and how do you know to replace them? OK. That's two things. :deerMrA":ecz7vwuv said:krismusic":ecz7vwuv said:Hmmm. Thanks for the replies. I like the idea of treating my tools like swords! :twisted:
Use silica gel packs, we use them at work for the more specialised workshop tools that are stored in a pretty basic store, if you can box them and pop a couple of silica packs in there then your tools will be fine. If you're local to me I could get you some packs, just let me know how many you'd need.
That's spooky! My wife is madly into hand spinning with drop spindles. She's always at it! It's like living with a bloody spider! Do you have a website? All the very best. If you are managing to stay out of the clutches of the benefit system then you are doing well in my book. From what I hear the dole is run as a penal rather than supportive department these days. :evil:tekno.mage":2udz69oc said:We mostly sell our work in the local area - in local shops and also at local craft events - one of our selling points is that our work is hand made and uses local, sustainably produced, named woods. For some reason our hand made crochet hooks, giant knitting pins and drop spindles are very popular! We also have some customers further afield that we do production turnings with special paint finishes for - again these customers like the fact we are using local wood and are based in Wales. We definitely need more outlets & clients but so far all our business has come via word of mouth and I'd really like to keep it that way to avoid time-wasters & non-payers.
We don't try and compete with cheap machine-made imports - there is no way we can - we are aiming for the premium end of the market in craft tools. We also make decorated bowls and boxes with threaded lids which are more the art end of the market, and light pulls in named local woods, which is the cheaper end of the gift market. All our products are labelled with the woods used - in English and in Welsh (even though we are not native Welsh speakers).
We both had proper jobs once - myself in IT management and my partner in electronics design, but a combination of redundacy and other factors led us to Wales - supposedly to retire, but the pensions didn't work out as expected We have to do something to make a living, & there are very few jobs around here in the current financial climate, so we decided to turn what started out as a hobby into something more - and so far it's turned out just slightly more lucrative than being on the dole!
krismusic":1aiy4zer said:That's brilliant. I am in London so not local but thanks very much for the offer. Presumably I will find silica packs online. One thing about silica packs. How long do they remain effective and how do you know to replace them? OK. That's two things. :deer
krismusic":qoxqggat said:[q
