LFS19
Presumably that white along the top of the plaster is okay?
Slightly paranoid :O
Sent from my iPad using Tapatalk
RogerS":2frtbrs2 said:skipdiver":2frtbrs2 said:Not heard of asbestos in plaster. Artex yes.
And guess who's probably moving to a house with Artex ceilings
Tempted to plasterboard over and get it reskimmed. The plus side of removing it is that I can see where pipes run etc.
skipdiver":29u6oeib said:RogerS":29u6oeib said:skipdiver":29u6oeib said:Not heard of asbestos in plaster. Artex yes.
Best to leave alone and skim over it. You could board over it but we just used to knock off the high spots with a big scraper and skim straight over the lot. Needs a couple of thick coats of plaster to conceal.
skipdiver":1hind70p said:I wondered if that is what you meant but went with the obvious. It's nowt to worry about. Could be trowel marks or wallpaper paste, maybe a bit of efflorescence or bloom as some call it. If it's loose, brush it off and seal it.
MikeJhn":24mo7lde said:Nobody can tell you if the areas you are concerned about contain Asbestos from Photographs, there is only one way to be sure and that is to have it tested, very expensive and will just feed you current state of paranoia, no offence intended, when Asbestos first started to be used in the Construction Industry it was expensive and was only used commercially because of that, when surveying domestic buildings I always worked on the adage that it the building was built in the 50's/60's it would contain Asbestos in some form or another, but not prior to that date, looking at your pic's I am making a big assumption here that your house is Victorian, in which case I would not expect to find Asbestos in any great quantities for a number of reasons, mainly that any that was used during the prolific use period would have long gone due to renovations and alterations in the interveaning period.
Just one other thing, White Asbestos is a designation of its type, it does not neccesaraly mean it will be white in colour.
Mike
skipdiver":1aa6kiwf said:The lath and plaster is original and wouldn't have been used in a modern-ish extension. If it's any consolation LFS, the most dangerous forms of asbestos are blue and brown types but i wouldn't get too paranoid about white asbestos because as Mike points out, the colour is just a designation and not necessarily that colour in reality. As a joiner, i am in the highest risk group for developing asbestosis, which i was told by a member of DASH, which is the Derbyshire Asbestos Support Team. I try not to dwell on it because as a young man, we knew nothing of the dangers and i may well go on to develop the condition, or i may not. If you are worried, you can get it tested but it will be majorly expensive.
skipdiver":1du1mzvq said:The lath and plaster wall tells me that it is not an extension as they wouldn't have used that in the 80's or 90's. The plan confirms that and it gives you some ideas to how houses get altered over the decades to suit their purpose at the time. My house was also built in the 30's and to my surprise, has breeze block internal walls. They are a very crumbly type that were probably made from waste of the steelworks up the road, though i'm just guessing there.
