LFS19
skipdiver":1gzyvyov said:At some point the wall has been boarded over and skimmed, either all of it or part of it, again it's difficult to tell from the pictures. Plasterboard and water is not a good mix, so some or all of that may have to be replaced. In your position i'd probably rip the lot off and start again but it wouldn't be a big deal for me to do as i have done plenty of that sort of work. If you have stopped the source of the leak, then it may well dry out sufficiently but again it's hard to tell. Where is the shower in relation to the wall and is the shower staying put?
Interesting.
The shower is directly behind that wall on the left where I've chipped away at the plaster.
I've marked the width of the shower here on this picture and it's location. It's about 70cm.
Essentially whats happened is the waste pipe that's underneath the shower tray has leaked, causing water to come through in the ceiling below.
The floorboards in front of the shower as you step out of it have been damp from the leak, as well as the boards you can see in this room that go under the floor and into the bathroom.
How far that damp extends is the real question..
I don't know whether it's confined to the width of the tray or not, so I'm guessing I'll need to remove the plaster/plaster board patching right along the width of that wall on the bottom to see what the damage is.
Further on from where the width of the shower ends some evidence of damp can be seen on those lighter boards, but I'm not sure.
As far as what we're doing with the shower, we'll likely just rip the lot out.
It's going to cause such a mess a sort out this leak that it makes more sense to re-do it.
The shower is a decent Mira excel but it's over 10'years old now.
Knowing my luck I'd sort the leak out and repair the damage to find a couple of months later that the valve was leaking onto the wall behind
Sent from my iPad using Tapatalk
