RogerS":q53vkr55 said:LFS19..are you sure that the damp on top of the floorboards isn't a leak from the shower door/frame? If you have a leak from the waste pipe then that is below the level of the floorboards.
MikeJhn...what would you use on a stud wall if not plasterboard ?
LFS19":2rq5flma said:RogerS":2rq5flma said:LFS19..are you sure that the damp on top of the floorboards isn't a leak from the shower door/frame? If you have a leak from the waste pipe then that is below the level of the floorboards.
Perhaps it is the door, but could the door really cause all that damage coming into the other room?
Regarding the waste pipe - 90% will be running under neath the floorboards, but I'm wondering even if it's just that small section that runs from the plug hole to underneath the floorboards.
Then there's the issue with water leaking through the ceiling. It wouldn't happen with a short shower, but with a longer one.
RogerS":bna1zbom said:LFS19":bna1zbom said:RogerS":bna1zbom said:LFS19..are you sure that the damp on top of the floorboards isn't a leak from the shower door/frame? If you have a leak from the waste pipe then that is below the level of the floorboards.
I've not read through all the thread but we had a similar problem in our house. The person who installed our shower 20+ years ago was a numpty and at the time didn't know what they know now. So the backer for the tiles in the shower was not correct, the tiles and grout developed cracks and leaks which got behind the tiles, soaked into the backer, dripped everywhere and through everywhere.
The solution was to rip it all out and re-install using proper backer boards suitable for a waterproof environment. Also some shower trays in the early days did not have upstands and so a crack at the bottom between tiles and shower tray and silicon was inevitable leading to water ingress there.
skipdiver":22rtl52x said:It could well be the cubicle that is leaking, especially if it was fitted by someone not so knowledgeable and even if it was fitted by someone in the know, it could still develop a leak somewhere. Just a small one would cause a bit of damage over a long period of time. I have fitted quite a few showers and yet my waste pipe still managed to work it's way loose and soak my kitchen ceiling bringing down a length of plaster coving. I hadn't tightened it properly in my haste and it parted after about a year. It needs some investigation as it could be leaking from any number of places and may be as simple as removing old sealant and re-sealing. Another area showers leak is the join up the corner where the tiles meet. People grout this join but that's not the correct way to do it as it invariably cracks with natural movement. Sealant matched to the grout is the correct way as it's flexible.
Useful trick is to shine a powerful torch against/along a wall - it may pick up the ghostly outline of previous alterations, as well as showing that everybody's plastering is carp under a bright light!skipdiver":1o7zys5k said:You are dealing with years of other peoples alterations. Doors get blocked up and doors opened up into walls that didn't previously have them. Walls get put in, taken out, boarded over, re-skimmed. Cupboards get removed, floors get patched up after plumbers and electricians. If the walls in question are fairly sound and the leak sorted, then just fit your new skirting and redecorate. Put down a carpet or laminate floor on good underlay and forget about it.
I would have removed it all and started afresh but i have the knowledge to do that and only have to pay for materials. For someone like yourself, just keep it simple and stick to the basics.
Jacob":niqw30ht said:Useful trick is to shine a powerful torch against/along a wall - it may pick up the ghostly outline of previous alterations, as well as showing that everybody's plastering is carp under a bright light!skipdiver":niqw30ht said:You are dealing with years of other peoples alterations. Doors get blocked up and doors opened up into walls that didn't previously have them. Walls get put in, taken out, boarded over, re-skimmed. Cupboards get removed, floors get patched up after plumbers and electricians. If the walls in question are fairly sound and the leak sorted, then just fit your new skirting and redecorate. Put down a carpet or laminate floor on good underlay and forget about it.
skipdiver":l2vu8nli said:Not heard of asbestos in plaster. Artex yes.
MikeJhn":2taioafq said:Asbestos was regularly used in plaster up to the end of the 1960/70's although this was mostly in industrial buildings, I would doubt that your plaster or walls contain it, but do take care with your roof soffit and barge boards, these where very often constructed with Asbestos sheet.
Mike
skipdiver":p190pta7 said:Not heard of asbestos in plaster. Artex yes.
RogerS":3ej0yq69 said:skipdiver":3ej0yq69 said:Not heard of asbestos in plaster. Artex yes.
And guess who's probably moving to a house with Artex ceilings
Tempted to plasterboard over and get it reskimmed. The plus side of removing it is that I can see where pipes run etc.
