You raise some great points.How can you claim that climate change can only have happened since the industrial revolution ?
I don't think so. Urban myth.I heard apparently even glass moves so very old panes will get thicker at the bottom. Don't know if it's true.
It isn't true.I heard apparently even glass moves so very old panes will get thicker at the bottom. Don't know if it's true.
Glass does move but it is hardly measurable over geological time scales.I heard apparently even glass moves so very old panes will get thicker at the bottom. Don't know if it's true.
I think one has to seperate "pollution" from factors that may impinge on climate.You raise some great points.
You also seemed annoyed. As you probably gathered by the original question i am by no means knowledgeable on this stuff, however, do you honestly believe we havent had a large negative impact?
I do know that the earth has cycles and they have a big impact on the climate, but seriously, do you think our way of living hasnt had a big impact? All the extra co2 and other emmisions etc, wiping out forrests, massive mining, PLASTIC, concrete and anything else you want to add...... im not an eco warrior, i have lots of material rubbish i dont need ( including a recently purchased air con for the front room ) but even i can see the sheer scale of change in our lives and daily consumption of 'stuff' since just the 80's and 90's to now.... it's staggering.
But there is masses and masses of evidence gathered from many sources over many years which makes the conclusion unavoidable.....
My argument is that , just because there may be a correlation between CO2 levels and changes in climate - there is no proof that this is a CAUSE of climate change or an EFFECT of climate change.
There are not. All the scientific arguments point in the same direction.There appear to be equal arguments both ways.
Agreed. Rheology, the study of flow in response to stress is the relevant subject matter. Flow is most commonly associated with liquids, but In reality everything flows, even materials people think of as solid, such as steel, concrete or wood. I recall some years ago hearing about how scientists missed to physically be there to observe (it was at night, or something when they were at home) the first drip of a very viscous substance or fluid they'd set up in an experiment. The idea was to see how many years or decades it would take for a drip to happen in the substance in their experimental laboratory conditions. I've no recollection now why they felt it important to undertake the study, but I think they at least had a video running when the drip, er, well, dropped, ha, ha. Slainte.Glass does move but it is hardly measurable over geological time scales.
Scientific research often has no obvious point at the time other than satisfying peoples curiosity and intellect. Then maybe ten or fifty years time it is suddenly useful.Sgian
they did it because it's a great way to keep ur job....
guess they will all be paid a fat salary even if the first blob takes a decade......
men in suits again.....parasites.......
not all experiments are wasteful tho, before anyone has a go.....lol....
Every activity affects the climate.I think one has to seperate "pollution" from factors that may impinge on climate.
I totally agree that our modern way of living is having a negative impact on our environment.
Clearing rainforest is really terrible and may ( and probably will ) have a severe effect on the planet's climate balance. Mining, however, is a pollutant - which can destroy the environment but not necessarily impact climate.
With the example of mining, especially modern versions, there's a fair amount of pollution as a by product.Is the resulting pollution causing more damage than the problem it claims to solve ?
Interestingly, i think it is true..... the outer surfaces are more 'set' and the middle is more 'fluid', although not in the sense of actually molten obviously.It isn't true.
The simple fact is that if you are putting old crown or otherwise irregular glass into frames it's sensible to put it thick end downwards for strength. An old small sash pane might vary from 4 to 1mm in one piece.
Better stop breathing - it emits CO2 and water vapour ( the most effective greenhouse gas ! )Every activity affects the climate.
You are correct that breathing emits C02 and water vapour but as if you suggest we were eliminated from the face of the Earth I am not sure our breath would make a difference. We would be replaced by other large animals who would also breath.Better stop breathing - it emits CO2 and water vapour ( the most effective greenhouse gas ! )
So taking your assertion to the extreme - eliminate humans and their activities, and climate will never change. Unless, of course, there are other factors.
I would assume you would then assert that climate on this planet never changed before human presence ?
Geological core samples ( SCIENCE ) would seem to disagree with that.
It is really interesting, that a reply would start by a small recognition, but avoid the thrust of the argument - by changing ( warping ) the subject.You are correct that breathing emits C02 and water vapour but as if you suggest we were eliminated from the face of the Earth I am not sure our breath would make a difference. We would be replaced by other large animals who would also breath.
It is what we do that makes a difference. We have the capacity to undertaking things like mining which certainly effects the climate.
As you quoted above "Every activity affects the climate".
If I paint my roof white it will reflect some of the sunlight reducing the heat inside the house. For the most part we do not need much cooling (so far) in the UK so a reduction in the temperature of the house may not be a positive benefit as it would also reduce the temperature in the winter when heating is required so more CO2 would be produced. If I lived in the south of Spain where not so much heating is required in the winter but cooling may be required in the summer then painting the roof white may have a positive benefit. As an individual painting my roof white in Spain may reduce my electricity bill but will only have a very small effect on global CO2 production. If it became common it would have an effect.
Nonsense......
Climate change has become a "religion" and there are believers and non-believers.
