Walnut and painted WIP
Doug B":glok5ncb said:
JonnyD":glok5ncb said:
You`ve painted the workshop walls orange :?: :shock: :shock: :shock:
They have always been orange I have knocked down the office that was in the corner and inside was painted orange by the previous tenant.
This is what was removed
Jon
Great post, thanks.
You inspired me to use the method for face frame beading for some cabinets. Apart from one corner it worked a treat.
This post makes it look so easy, the reality is you need very very well set up machines and for us with a small space then it takes so much longer.
I look forward to learn how you made the doors for the curved cabinets. Are the curved rails done from one piece of wood then?
angelboy":1ipfe70b said:
Where in Lincs are you?
Just outside of Boston
the_g_ster":1ipfe70b said:
Great post, thanks.
good to here this curved doors coming up
cheers
Jon
So onto the curved doors mostly in the past we have made shaker doors but these ones have a mould so a bit more tricky.
First job was to make the former for the curved panels about 30 pieces of 25mm mdf were cut to the same size and some 10mm holes were put in using a router and guide bush through the template. The pieces are then assembled onto some threaded rod.
The finished former was skinned in 1.5mm ply but i forgot to photo that
The panel is made up of 2 pieces of 1.5mm ply with a 3.2mm piece of bendy ply in the middle. The 1.5mm ply was used on the show faces as the bendy ply grain is quite coarse
this sucks
The frame component were cut from the solid and machined the same way as frame components previously.
A curved saddle was made to hold the curved rails in the tenoner at the right angle and the cut made
Components tenoned
A scribe cut was made on the router table
The ballache with this was always how was the mould going to be put on the curved rail as the cutter works with the stock flat in the end it was quite simple. some curved parts were screwed onto the router table fence and the bits fed through. You have to lower the cutter slighty than the setting for the flat stock as i found out on the test bit probably to do with the arc or something
Just the groove to put in now. 6.35mm cutter in the router table a curved fence and about 4 3mm deep passes
The former was used to get a datum on the panel to get it square without being twisted
It works a dry run of assembling the door
Thanks for looking
cheers
Jon
Fantastic Jonny, keep them coming.
Really interesting to see the curved work.
You surely don't use that fookin big hammer to knock your doors together do you? :shock:
Nice thread Jonny. Very interesting systems and unbelievable Tekkkkkers on display.
Cheers guys
They only needed a light tap :D I don't actually know what it's doing there the doors are assembled using a counterbored screw as its pretty much impossible to clamp them up without a lot of jigging about.
Jon
Awesome wip.
Though all of a sudden I feel a bit humbled at the skill some people have, thanks for sharing though.
Thanks for the comments :D
So on with the top
Some expensive 3inch walnut
The top is going to end up at 60mm thick so I decided to do the top glue up in 2 hits firstly the stock was joined into smaller sections the thickness at the moment is 65mm
These sections are then resurfaced and thicknessed down to 60mm due to the size and weight these pieces are jointed on the sliding table with a fine cutting blade
A dry run was done to check everything was straight and level. You can see the double row of dominoes as well
I didnt have enough cramps of sufficient length so 22 sash cramps were bolted together to get 11 the right length
Glued with UF resin
The floor is uneven in the workshop so the tops of the trestles are leveled so hopefully the top will be nice and flat when the clamps are released
I have also been glueing up the carcases
Thanks for looking
cheers
Jon
How well did the joints turn out in the worktop? Looks good, that worktop will be impressive.
That's a stunning top to finish off some remarkable work, don't envy you having to handle that weight of the slab to finish it off, or the completed unit for that matter.
