Time for a bit of an update on this.
Started off using the router and homemade trammel to cut arcs so templates can be made to make the curved rails for the island unit
Using the bobbin sander in one of the spindle moulders to help shape parts for the jig
This jig is for the inside face which is machined first. The rails are initially made slightly long so that they can be screwed to the jig
Because of the curve you are machining against the grain for half the cut which can result in some torn grain. To counteract this on the wadkin spindle you can change the rotation of the block easily and by turning the block over you can machine both parts with the grain and avoid tearout. It only takes a few seconds to change the block over.
rail loaded onto the jig
You can see from this video how the machining is done with the block turned over and the rotation reversed
After the rails are made they need cutting to length at the right angle. A full size rod is drawn up on some mdf to guage lengths and angles
A simple jig is made to put on the sliding table to make the cut at the right angle
The other end is a slightly different angle so some more stops are placed on the saw
Testing for fit
The mitre on the rail for the beaded frame is done by hand with the router
To domino the curved rails into the sides a piece of packing is added to the domino to allow you the present the tool at the right angle
Dry run to see if they fit
Frames are glued and cleaned up by hand with a bevel up smoother
Some detail is put on the legs with a V cutter in the router table
The legs are also stop chamfered done by hand to marks as i couldnt be bothered making a jig or setting up stops on the spindle
The frames are dominoed onto the legs bit of heath robinson clamping to allow dominoing of the curved frames
Got the frames and legs together so that the carcases can be sized up
Thanks for looking
jOn
