Before i forget http://www.daltonswmw.co.uk sell parts for old machines .
Dom Valente":21xjwhve said:Need!! Who said anything about need, he should want them, nay, desire them, they're so pretty
Scrit":21xjwhve said:
JFC":f01g75my said:Thanks , i think that is what felder are offering me for £20 . The spring and upright bar .
If you can feel the limiters trying to lift the work away possibly either you're overfeeding or you need to raise the rotation speed of the cutter block. Your spindle moulder (the RS) has two speeds, 4500 and 7000 rpm, what diameter block were you running and at what speed. Unlike a router table feeds and speeds are much more important on a spindle. Incidentally you'll feel the "push-off" if the cutters aren't sharp or the limiters are too large as wellJFC":33x5jxrq said:I thought that when trying a crown moulding , the limiters i spose where trying to move the work away . Not a kick but i could feel it . It was fine just cleaning up rebates where i had taken most of the material away on the table saw .
Big motor pulley/small spindle pulley = 7000 rpm, small motor pulley/big spindle pulley = 4500 rpm on your machine. With a 100mm diameter block you should be running at the higher speedJFC":996yy1io said:It was running at "the belt came off and i put it back on RPM" :?
That's a replacement motor, but it will still be mounted on some kind of pivot. If Brad will give me permission, I'll post a photo of the innards of his tomorrow.JFC":2gf8v9vs said:I cant see anything like you describe Im wondering if its had its motor changed .
.JFC":2gf8v9vs said:What I thought you where describing as a greasing point with a grease nipple below it . It doesnt turn very far.
JFC":oihe5aht said:I cant see anything that will move the motor other than undoing the motor housing bolts and pushing it over by hand but i also didnt see anything to say that would work either .
The plastic top on the motor shouts 1980s or later to me, but could be late 1970s at a pinch I suppose. Prior to then even Italian alloy motors all seemed to have metal fan covers at the top. I just think they got their dating wrong. The machine was certainly made between circa 1947 (well, that's the earliest documented evidence I can find) and 1957 when the front plate became Wadkin-Bursgreen. The nice thing about these roller bearing spindles is they are very simple, repairable and have little to go wrong.JFC":6x1whs28 said:So the EBay description of it as 30 years old was the motor i assume.
They come in from the end of the machine. The larger is the rise and fall drive, connected to a handle at the RH side of the machine. I think the smaller one is the rise and fall lock. Can you confirm, Jason?Jake":6x1whs28 said:What are the threaded rods in the first picture?
