New to Tung Oil:
a) Which make of Tung Oil have you used and you liked the finish?--as there are various choices of make.
b) Did you apply the Tung Oil with a brush or cloth?
c) What make / type of brush? What type of rag?
d) If you applied several diluted coats did you rub down between coats? If so did you use wet & dry paper paper? Grade?or 0000 steel wool?
Many thanks--look forward to your answers.
