pe2dave
Will do. ~Currently favouring Oregon, lots of chains available. (And oil)If you do buy a cheap chainsaw, make certain that spare chains are redly available and buy a couple with the saw.
<chuckles/> I cut (ground) one of the roots that way, got a bit smoky! The arbortech wheel was clogging (fresh green wood) every 2 minutes Pete.I would clear away more dirt for access, pressure wash the bark clean. After leaving it a day or few for the dirt to dry out unless you like playing in the mud. I would use a 4 1/2" (or your equivalent) angle grinder and with an Arbortech type carving wheel, carve away the wood. The work will go fast.
https://www.arbortechtools.com/ca/shop-online/power-carving/attachments-accessories/turboplane
https://www.arbortechtools.com/ca/s...attachments-accessories/industrial-woodcarver
Or if you feel more comfortable with a guard around the blade.
https://www.arbortechtools.com/ca/s...nts-accessories/industrial-woodcarver-pro-kit
What about push sticks?I would clear away more dirt for access, pressure wash the bark clean. After leaving it a day or few for the dirt to dry out unless you like playing in the mud. I would use a 4 1/2" (or your equivalent) angle grinder and with an Arbortech type carving wheel, carve away the wood. The work will go fast.
An alternative for surface roots Pete?I would clear away more dirt for access, pressure wash the bark clean. After leaving it a day or few for the dirt to dry out unless you like playing in the mud. I would use a 4 1/2" (or your equivalent) angle grinder and with an Arbortech type carving wheel, carve away the wood. The work will go fast.
I guess so. Being for concrete etc it should not get bothered by dirt around the root but looks like it would be slower. You could prove it by racing your neighbour. Duelling grinders at 10 paces.
what you need is a mattocks https://www.amazon.co.uk/Mattocks/b?ie=UTF8&node=1938907031 the tool that we used to use befor stump grinders were invented ideal for removing tree roots found a better utube
Impressive! That's a major archaeological excavation. Note that once he has the roots clear he uses a reciprocating saw to cut through them, not a chainsaw.In extremis? A vacuum, a scraper and a drill to loosen dirt.
This guy eats chocolate elephants. I have to admire his patience.
A number of “digging post holes with a pressure washer” videos have appeared on my YouTube feed recently. It could be a low risk excavation technique to get under the stump to part the tap root.Advice accepted. I / we can't figure out how the panel is affixed (and only two of us). Concrete post, vert overlapping panel, horiz brace near top and bottom.
Also, I'm used to the 'mini' mattock.
I'm quite jealous of that guys soil - looks really fine (almost dusty) and so easy to dig!!!
Hah...that's a baby oneThe one I hired is about 30” at its widest point ( the wheels ) they are extremely heavy and will take 2 or 3 to lift it .. that said it hard work manoeuvring it into position and keeping it there but the end result is no ugly stumps..
Another 'odd one' is using very high pressure air to loosen soil!A number of “digging post holes with a pressure washer” videos have appeared on my YouTube feed recently. It could be a low risk excavation technique to get under the stump to part the tap root.
They do that in parks to counter compaction from people walking.Another 'odd one' is using very high pressure air to loosen soil!
'overdo it' and (could it?) would it loosen soil enough to ease stump removal?They do that in parks to counter compaction from people walking.
