Diy Steady rest ideas
johnnyb
13 Nov 2006
Biddulph staffs
I wondering if anybody has any great designs for long spindle steady rests that I can copy. I've ordered some online skate wheels.
That's the exact one Tim Mason makes and sells on ebay. I don't think it will be a big job tbh. Actually that design would be significantly stronger than Tim masons having a second support ring.
Used to watch Mike Waltd a lot for sensible turning info, this was his making of steady rest. I imagine it's a lot like many others, but here's the video link.
I think the ones with housings to hold the roller arms allow for greater rigidity if you get a catch.
Also, the ring form that most of them use as standard can be improved upon to give the optimum diameter possible, for a turning on the lathe. This can be done by having extra material on the outer diameter of the ring at three, or four fixed points, (depending on the number of arms used ) which will allow one to move the position of the fixing bolts further out. Material can then be removed from the inner circumference at these same positions, allowing the rollers to be tucked further out.
I have a design for woodturning that I haven't quite finished yet for a 170mm centre height lathe. This will provide for a max 110mm diameter workpiece. However, it really requires a milling machine to make, although some patient work with a file would do it. The "ring" in the photo attaches to the piece of steel angle which then bolts to the lathe bed. The ring is just a 12mm section from a large diameter steel pipe, cut to length by the supplier. If you want a dimensioned 2D drawing I can send you one. Very simple design really. Parts so far:-
    1.8 MB
I built this fifteen years ago. You need to make it to suit the lathe swing, that being twice the measurement of lathe centre to lathe bed. I used skateboard wheels, and Bandsawed out the size etc.
    1.1 MB
    1.1 MB
I have done simmilar to Mike Waldt one and one shown above. I was thinking long time about 3 or 4 spurs and decided for 3 due to being easier to adjust as well as less material needed. I used old wheels from my skates and some scrap wood from old crates. Once I get to a skate shop i will get smallest diameter wheels I can get to make it useable for smaller diameters. Unles I find the way how to grind down present wheels to smaller diameter. Tried it already but it is pretty messy process with sticky polyurethane dust everywhere.
Maybe I’m missing something but some seem determined to over complicate things by constructing round steady rests.
If you look a bit closer on the net there are plenty of ones that aren’t round and as a result look much less difficult or time consuming to make.
Some examples. Bottom one is a commercial unit from Amazon that could be home built as well.
Then again, if you want to turn something like a Trembleur you might want to make something like this. 😆
