Woodmonkey
Wow, interested to see how it all goes together...
A little off topic, but any more information on your press?Chrispy":2me75rc2 said:griggs":2me75rc2 said:https://www.ukworkshop.co.uk/forums/download/file.php?id=40560&mode=view
Is that your own shop built press ? How does it work?
Yes griggs home made air powered, it has a 12" dia air ram at the bottom making it an upstroke press ie with no power it will open so you can get your hand out
Hmmm, good question.Chrispy":3evuiaxh said:What do you want to know MM?
That's great thanks. Seems you got a bargain with that piston!Chrispy":2l33y35n said:I see, well I'm sure it's 12" dia with a working stroke of 6" which seems OK for me, the platterns are 4'x2' and works well for most jobs including veneering, I vary the air pressure depending on the area of work piece, with a maximum of 100 psi air pressure multiply by the surface area of the piston to give you your force you then need to divide this by the surface area of your work piece to give psi on your work. This piston I found advertised in a local paper over 30 years ago just a bit of luck really.
It's quite difficult to explain quickly so I think when it's finished I'll assemble it and try to show how it is meant to work.vanitycat":ifrvw4p1 said:I had a feeling that it was some kid of child playing equipment when I first started reading. But what are the open boxes for? Part of the governments scheme to get children off the streets and into boxes? ;-)
