skipdiver
Hi folks.
Spent the last year or more renovating my house and am now about to build a conservatory on the back, using single skin timber framing for the walls instead of the usual brick/cavity/block route. This will make the build quicker, give me more footprint and i won't need to get a bricky on site, which is good because funds are now running very low.
My questions concern how to approach the timber framing. My house is pebble dashed unfortunately and this will be painted to make it look half decent, which leaves me with the decision of what finish i want for the conservatory. I quite fancy some form of timber cladding but that presents a problem because one of the walls is within a metre of the boundary, so has to have "reasonable fire resistance" according to the powers that be.
Now as we know, conservatories do not come under building regs if certain criteria are met. One of those criteria is that the walls have to be a minimum of 50% glass. This rule is overridden in a boundary situation, where "reasonable fire resistance" is preferable to the need to keep to the 50% glass rule. With this in mind, i am going to build a full height wall on this side of the conny and am looking for suggestions as to what materials i can use to meet the fire resistance required.
I have been looking at composite cladding such as Marley Cedral for the 2 sides of the conny that are seen, but it seems a waste of money to put it on the boundary side, which is up against a fence and out of view. I've considered some kind of board that could be rendered and painted, but again, that means paying other trades for work i'd rather do myself because at the moment i am time rich and cash poor.
The inside of the wall can be done with firecheck plasterboard, but i am open to suggestions as to what material i can use on the outside for a rainscreen that is fire resistant and not too expensive, bearing in mind that looks are not that important. Maybe something that can be painted to match the house.
Any other hints or tips on single skin timber framing would be appreciated as well.
Steve.
Steve.
