Some 18 months ago this thread went strangely quiet. I had been distracted by a rather protracted observatory build in my garden which went on a tad longer than expected and is now all but finished.
The recent sad news about Richard brought me back to earth with a huge thump and I vowed to finish this plane so I can remember that truly remarkable guy until I meet him again, where no doubt he will want to discuss the finished build.
I was a bit unsure about continuing to post on the original thread but having spoken with Emma...she wants me to so I will...I just hope I can do it justice.
So...last time we discussed Richard's panel body infill...I hadn't moved on beyond the rear infill...so let's pick it up from there.
I decided to start on the bun yesterday...I have marked out the lever cap ready for milling and hand shaping:
....but I want to come back to that as I have other ideas in the pipeline to test involving older technology...wedges and bridges! :shock:
Ok...after clearing a few tons of junk and shavings from a mothballed workshop...and tidying the bench...I set about making the bun.
Making a quick template of the side gave me something to play with when selecting the stock...being burr it has many sides to choose from to get the best out of the figured grain and I had two blocks left over to choose from.
I roughly marked the thickness of the block so that it would be a tight, oversized fit into the front cavity...then shaved bevels all round to give me sight levels to plane to...( a fabulous tip picked up on UKW!)
I think it was Konrad Sauer who said once in his fine blog..."I am always thankful that I have infills to make infills!"....and he's darn right. This old panel plane with a Quangsheng (yes QUANGSHENG) iron...made light work of the thicknessing.
Of course...you have to check about a thousand times that you don't over-cook it but I eventually got to that magical thickness that just fits (with the aid of a sledge hammer :mrgreen: ).
Finally!!
And another Konrad tip for making sure it's a good fit...lift it up without the aid of glue, screws, rivets or nails...at the front....
...and at the same time lift it from the handle end.....
Et VOILA!
And if there is any camera shake on those two pictures it's totally down to me quaking in my boots!!! :mrgreen:
There is some serious grain at work on this block of wood....
...I can't wait to get it out into the open! 8)
Now..... Da Vinci I am not so excuse the rough sketch.....
Note the need for a caffeine fix at this stage!
......before I hit the bandsaw.
Some of you may recall my affection for the little Burgess Powerline bandsaw I picked up once for a tenner. And I do now have the utmost confidence in this surprising machine......
..... but this is limit time...nearly three inches of burr oak....guides to the stops...just fits under the arm....
This little baby never ever ceases to amaze me!! :shock: Of course...the
TUFF SAW/ blades are the real gems here! (wonderful stuff again, Ian! =D> )
So...a short time later and a few wiggles...
..a rough bun shape was formed.
I'd say we have some nice figuring beginning to emerge there...
Well...that's it for now...it was a bit late when I finished.....
In the next part I will cut the sides to width and tidy up the contours using the other great trick from Bill Carter...the squared end scraper chisel!
Cheers all...and Emma especially.
It's good to start work on Richard's panel infill again...I only wish it were under happier circumstances.
Jimi.
