Many thanks for all of those contributions.
Good point about using a dark glue although given the stuff has a shelf life, I think I would be more likely to mix a little acrylic colouring in than to have a tube of expensive glue hanging around on the off chance I fall heir to a piece of walnut.
Nobody has disagreed on the strength of a joint being a function of the design and quality of the execution so I'm not particularly convinced that strength (especially of one proprietary brand against another) is that relevant. More to the the point is, as contributors have mentioned, there are extremely good technical reasons for selecting cyanoacrylate, epoxy, polyurethane or urea formaldehyde for the characteristics of the application.
Somebody mentioned hide glue – is that made out of boiled dead animals or is it some sort of vegan substitute – I thought the stuff had to be kept in a warm pot. Likewise is Cascamite a urea formaldehyde glue? I know they changed the formulation, made a mess of it and reverted but even the so-called “original” stuff doesn’t seem to contain casein which was where the name came from. Inspired by that knowledge I used to stick labels onto beer bottles with milk which is admirably biodegradable and allows one to re-use the bottles. I can live with having to mix up Cascamite because I'm so slow that long tack times suit me fine! On the other hand I wouldn’t use it for the grand piano I’m building for the reproduction R101.
I'm probably a bit nerdy about glues because my grandfather was a polymer chemist between the wars although I didn't learn much chemistry from him I certainly recall how excited he got when epoxy resin came out. What prompted the original question was the whole business about people getting all excited about Titebond as opposed to generic PVA - is that just a YouTube thing? You wouldn’t import cement, nails or any other building commodity from the other side of the world. I’m thinking about what you are really buying. If you buy Aerolite 206 or indeed a D4 PVA you have a spec, but with a “branded” glue you’re potentially buying a tub of chemicals that somebody in the marketing department thought had a “trending” colour.
