I tried to cut some sycamore square on my Draper tablesaw today.
It didn't work, coming out skewed
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Now, I'm not too clever when it comes to handling tablesaws because I find them noisy and quite scary, but we've got a decent Freud blade on the machine so it should work okay. I think the problem lay in having a diddy mitre guide which was at full stretch, thus making it difficult to keep the wood stable as it was fed through. In fact the whole saw is quite diddy with a table that only measures 66 cm x 40 cm.
I'd like to pick the collective brains of the forum - I think I need a tablesaw with a bigger bed and capacity. What does everyone else think? If the concensus is that a new tablesaw is really needed, which would be most suitable, bearing in mind that I don't want one that'll take over the shop. I'm not worrying about the expense right now (although that'll be a consideration later) so long as the most appropriate machine can be identified.
I've tried using a home made panel cutter jig but it's a pig to manouvre, being bulky and in need of support from a wider table.
Changing the subject, it was a delight to sit chipping away at some marquetry with decent light to work in. I've not had such a pleasant working environment for years! This is the 'work in progress' piccy - I'm not sure what I'll do with it when it's ready to lay.
[Rolf Harris mode] Can you tell what it is yet? [/Rolf Harris mode]
Gill
