Wizard9999
I agree that the post by HOJ is really interesting and helpful. If I understand the extract correctly the key is that if you have OSB on the outside of the frame you can't rely on OSB alone on the inside, as by definition the vapour resistance will be 1:1 and not the recommended 5:1. But from your post you are using a 'proper' vapour control barrier on the inside which I presume is designed to give exactly what is needed.
Terry.
Edit: weather came on just after I posted this, certainly sounds like a good thing that you have structural integrity as it sounds like it is going to get seriously windy later this week!
Terry.
