matthewwh
A A Milne would have been proud of that one!
woodbrains":36fdkefh said:Hello,
But stropping as has been suggested here has a sharpening effect, akin to the ruler trick, which would be my definition of stropping, not removal of the wire edge, which has always been refered to as 'the removal of the wire edge' or removing the burr. Hayward is describing 2 different things here and caused confusion by using the name of stropping for both. But let us not be confused, there is a distinct difference in result, and we know it.
Mike.
Either. If you rub a piece of metal for long enough with a piece of leather, or your hand, or probably almost anything, it will polish up. This is good for cutting edges as there will be less friction resistance behind the edge. If you add abrasive it will polish up but differently, according to the abrasive.David C":352obzd3 said:Do we believe that leather has abrasive properties?
Is the strop plain leather or charged with a fine abrasive?
David
Cancer? Things are getting serious! Tiny bevels spreading through the tool box :shock:CStanford":36wmpy8k said:I do appreciate the fact that ruler trick proponents understand that jigging is an absolute requirement to prevent the tiny back bevel from metastasizing, which it surely would do without the ruler.
David C":3q49qika said:Do we believe that leather has abrasive properties?
David
woodbrains":nk60hmgg said:If anyone thinks that an edge sharpened on site by a joiner, using the usual India stone or similar, can be observably or measurably improved by stroking it back and forth on the palm of the hand, is really indulging themselves in mythic folklore.
Mike.
G S Haydon":2bkcqsbr said:Dunno, seems to improve things for folks I've been around. It's been mentioned in text too, not now but in past when trades relied more heavily on hand tools. It's unusual for people to develop a practice like that just for fun.
n0legs":87r0blfq said:Just a thought,,,, my barber doesn't seem load up his leather strop with anything, a quick swipe then it's on to the shaving and he ain't cut me once.
bugbear":3lzhitiv said:Once a strop is loaded, it needs very, very little additional compound to keep working on a day to day basis. Once a week would be a lot.
MIGNAL":35qdpuhc said:My procedure is to start with a 1,000G, to 6,000G, finishing with an 8,000G waterstone. Then on to leather charged with the Green compound. Then leather without the compound, followed by soft tissue paper, then soft tissue paper charged with my Oil of Olay. Finally I blow straight across the blades edge. It's so highly polished that I can see Neptune!
Paul Chapman":1thibk8z said:bugbear":1thibk8z said:Once a strop is loaded, it needs very, very little additional compound to keep working on a day to day basis. Once a week would be a lot.
I agree. Some people seem to use far too much honing compound on their strops, and end up with a thick, gloopy surface. You need very little honing compound.
Cheers :wink:
Paul
n0legs":wp9h3okv said:G S Haydon":wp9h3okv said:Leather is skin and skin is what covers the palm of your hand.
bugbear":175ack6m said:Once a strop is loaded, it needs very, very little additional compound to keep working on a day to day basis. Once a week would be a lot.
It is normal for barbers to dress their strops (I bought some strop dressing from a specialist barber's supply shop n Norwich), and I don't suppose
that your barber is different.
I fully believe that you've never seen him dress his strop..
BugBear
CStanford":175ack6m said:The wax sticks are the wrong product. They are designed for power buffing where the wax melts and exposes the grit when touched to the running wheel.
iNewbie":175ack6m said:Ah, but our skin is untanned though - unless you have the George Hamilton thing going on... :wink:
/pedant
