Adam W.
A Major Clanger
A gouge can be used upside down without an inside bevel, so what does it achieve except adding a couple of extra steps to the sharpening process?
It's a different cut. In trad joinery an "incannel" gouge is used, known as a "sash' or "scribing" gouge and used most often for scribing window ovolo mouldings, rather than mitering them. You could do it with a normal gouge but less easily.A gouge can be used upside down without an inside bevel, so what does it achieve except adding a couple of extra steps to the sharpening process?
A sash gouge is a carving gouge. One bevel inside instead of out, which is what "incannel" means.We're talking carving gouges though and as far as I understand the previous post, he's talking about having both an inside and outside bevel on the same tool.
Why on earth not?.....
I know what a scribing gouge and a paring gouge is, I've been a carpenter joiner for 40 years a I wouldn't want to take them anywhere near a woodcarving.
Are you suggesting that carving gouges can't be used upside down if they don't have an inside bevel ?of course you may or may not want a small inside bevel. but it does lower the push angle in general use.it also can save rusty gouges. but in general use it effectively makes many gouges twice as useful because they can be used upside down.
They can be used any way you like. You can crack nuts with the handle end. Not many people know this.Are you suggesting that carving gouges can't be used upside down if they don't have an inside bevel ?
I think about it every day and to be honest I've never had a problem using mine upside down without an internal bevel.think about(or try it) without some lift it's not possible to clear the handle(your knuckles) past the length of the blade. why do you think backbent gouges are back bent. of course that's on straight and gentle hollows. why are straight carvers double bevelled?
I know that Internet forums can be places to raise pointless arguments about stuff but if you could take the time to answer the o p s question by explaining your method then the forum will be a healthier place. for instance I wouldn't sharpen a gouge without an electric grinder and Jacob wouldn't let one near. his method is equally valid(but slower).
